I am using HPC SDK 22.7 compiling code with NVFORTRAN, I am getting the following error:
senl@senl-computer:~/wepcuda/cudadaima$ make
nvfortran -Mcuda -c init_Weplspace.f90 -o init_Weplspace.o
NVFORTRAN-S-0155-sum is use associated and cannot be redeclared (init_Weplspace.f90: 5130)
0 inform, 0 warnings, 1 severes, 0 fatal for reads_sediment_para
make: *** [Makefile:40:init_Weplspace.o] error 2
The CUDA Fortran module includes a device callable version of the Fortran ‘sum’ intrinsic. Hence you can’t redeclare a ‘sum’ in your code. To fix, either rename your ‘sum’ to something else, or rename the module intrinsic. For example:
Mat,I have some problems,I hope to have a case written with cuda fortran to guide me to get familiar with how to complete a compilation, run and debug, but I can’t find it. Do you have a case package that uses cuda fortran to write code?
