This topic was originally under a different title, here’s the salient:
I get 404 from both of these from home using firefox, chrome, and safari. From home and onsite using wget and curl give me results I associate with same (see below).
https://developer.download.nvidia.com/hpc-sdk/rhel/x86_64
https://developer.download.nvidia.com/hpc-sdk/rhel/aarch64
I can’t currently get to the GP/GPU cluster but here’s the OFED from the A64FX cluster:
https://linux.mellanox.com/public/repo/mlnx_ofed/latest/rhel8.7/x86_64/
That link is indexable by wget and curl, and browsable by firefox, chrome, and safari, from home and onsite.
Here’s verbose curl output attempting the aarch64 hpc sdk:
16:53:28 ~/nvtemp $ curl --verbose https://developer.download.nvidia.com/hpc-sdk/rhel/aarch64
* Trying 152.195.19.142...
* TCP_NODELAY set
* Connected to developer.download.nvidia.com (152.195.19.142) port 443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
* successfully set certificate verify locations:
* CAfile: /etc/ssl/cert.pem
CApath: none
* TLSv1.2 (OUT), TLS handshake, Client hello (1):
* TLSv1.2 (IN), TLS handshake, Server hello (2):
* TLSv1.2 (IN), TLS handshake, Certificate (11):
* TLSv1.2 (IN), TLS handshake, Server key exchange (12):
* TLSv1.2 (IN), TLS handshake, Server finished (14):
* TLSv1.2 (OUT), TLS handshake, Client key exchange (16):
* TLSv1.2 (OUT), TLS change cipher, Change cipher spec (1):
* TLSv1.2 (OUT), TLS handshake, Finished (20):
* TLSv1.2 (IN), TLS change cipher, Change cipher spec (1):
* TLSv1.2 (IN), TLS handshake, Finished (20):
* SSL connection using TLSv1.2 / ECDHE-RSA-AES256-GCM-SHA384
* ALPN, server accepted to use h2
* Server certificate:
* subject: C=US; ST=California; L=Santa Clara; O=Nvidia Corporation; CN=developer.download.nvidia.com
* start date: Dec 2 00:00:00 2022 GMT
* expire date: Jan 2 23:59:59 2024 GMT
* subjectAltName: host "developer.download.nvidia.com" matched cert's "developer.download.nvidia.com"
* issuer: C=US; O=DigiCert Inc; CN=DigiCert TLS RSA SHA256 2020 CA1
* SSL certificate verify ok.
* Using HTTP2, server supports multi-use
* Connection state changed (HTTP/2 confirmed)
* Copying HTTP/2 data in stream buffer to connection buffer after upgrade: len=0
* Using Stream ID: 1 (easy handle 0x7f926f80d600)
> GET /hpc-sdk/rhel/aarch64 HTTP/2
> Host: developer.download.nvidia.com
> User-Agent: curl/7.64.1
> Accept: */*
* Connection state changed (MAX_CONCURRENT_STREAMS == 100)!
< HTTP/2 301
< cache-control: max-age=604800
< date: Thu, 16 Feb 2023 21:53:36 GMT
< expires: Thu, 23 Feb 2023 21:53:36 GMT
< location: https://developer.download.nvidia.com/hpc-sdk/rhel/aarch64/
< server: EOS (vny/B289)
< x-vdms-version: 3.42
< content-length: 0
* Connection #0 to host developer.download.nvidia.com left intact
* Closing connection 0
16:53:36 ~/nvtemp $
Here’s the same for the OFED:
16:58:50 ~/nvtemp $ curl --verbose https://linux.mellanox.com/public/repo/mlnx_ofed/latest/rhel8.7/x86_64/
* Trying 168.62.212.37...
* TCP_NODELAY set
* Connected to linux.mellanox.com (168.62.212.37) port 443 (#0)
* ALPN, offering h2
CApath: none
* ALPN, server did not agree to a protocol
* subject: C=US; ST=California; L=Santa Clara; O=NVIDIA Corporation; CN=linux.mellanox.com
* start date: Jul 5 00:00:00 2022 GMT
* expire date: Jul 5 23:59:59 2023 GMT
* subjectAltName: host "linux.mellanox.com" matched cert's "linux.mellanox.com"
> GET /public/repo/mlnx_ofed/latest/rhel8.7/x86_64/ HTTP/1.1
> Host: linux.mellanox.com
> Accept: */*
< HTTP/1.1 200 OK
< Date: Thu, 16 Feb 2023 21:58:56 GMT
< Server: Apache/2.4.6 (CentOS)
< Connection: close
< Transfer-Encoding: chunked
< Content-Type: text/html;charset=UTF-8
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 3.2 Final//EN">
<html>
<head>
...snip snip...
