I could not find this answered in the discussion group.
As far as I can tell the Mellanox HPC-X MPI is built without the option: --enable-mpi-thread-multiple
to the OpenMPI configure script. Is this intentional, and if so: why?
To test and verify try the osu benchmark sample that comes with HPC-X:
$ mpirun -host localhost -x MLX5_SINGLE_THREADED=n -np 2 $HPCX_MPI_TESTS_DIR/osu-micro-benchmarks-4.4.1/osu_latency_mt [1430755920.480363] [login0401:2589 :0] sys.c:741 MXM WARN Conflicting CPU frequencies detected, using: 2601.00 [1430755920.479771] [login0401:2590 :0] sys.c:741 MXM WARN Conflicting CPU frequencies detected, using: 2601.00 MPI_Init_thread must return MPI_THREAD_MULTIPLE! ------------------------------------------------------- Primary job terminated normally, but 1 process returned a non-zero exit code.. Per user-direction, the job has been aborted. ...
This test never runs due to the MPI run-time not providing the sufficient level of threads support.
/Nils
