Hello, I was wondering if there is a Nvidia library optimized High-Performance Conjugate-Gradient (HPCG) implementation available for downloading. Target is a Haswell cluster of K80 GPUs.
Michael
Michael
Thanks for the pointer drM … Does it adapt its run-time behavior based on the total number of available GPUs per node?
Best regards
Michael
Yes, you schedule one MPI rank per GPU and the code automatically assigns one.
For example, to run on two nodes with 4 GPUs each, a similar command should be specified:
mpirun -np 8 ./xhpcg_cuda6.5_openmpi
Does there exist a version for the tegra k1 board, too?
Unfortunately, the binary x86 version is not compatible with this arm board :(
There is no public binary for ARM.
Thank you for your answer.
If its not public available, is there a way to get it non-public for internal use only?
