Hello.
I’m using cusparseDcsrmv, one of the CUSPARSE library function, and I’m getting access violation from _hpf_bcopysl.
What is _hpf_bcopysl and what is its role?
Hello.
It’s the Fortran runtime’s routine to perform a bcopy with strides. Though, this is only called on the host. Are you using a device array on the host?
I’m just passing the device array pointers to cusparseDcsrmv and this function does the rest.
I don’t know what is happening inside this function.
This is a PGI runtime call so wouldn’t be called from a cuSparse routine. It’s occurring somewhere else in your code.
The problem is solved.
Segmentation fault was occuring due to invalid input argument.
But now I found another problem.
The following is one of the preprocessing routine that allocates device arrays.
SUBROUTINE AllocCMFDVar(Core, cuCMFD, cuDevice)
USE PARAM
USE TYPEDEF, ONLY : CoreInfo_Type
USE CUDATypeDef, ONLY : cuCMFD_Type, cuDevice_Type
USE CNTL, ONLY : nTracerCntl
USE GEOM, ONLY : ng
IMPLICIT NONE
TYPE(CoreInfo_Type) :: Core
TYPE(cuCMFD_Type) :: cuCMFD
TYPE(cuDevice_Type) :: cuDevice
INTEGER :: nxy, nz
nxy = Core%nxy
nz = cuDevice%myze - cuDevice%myzb + 1
ALLOCATE(cuCMFD%Cell_phis(ng * nxy * nz))
ALLOCATE(cuCMFD%Cell_src(ng * nxy * nz))
ALLOCATE(cuCMFD%Cell_psi(nxy * nz))
ALLOCATE(cuCMFD%Cell_psid(nxy * nz))
END SUBROUTINE
But on the calling side, I wrote like this
CALL AllocCMFDVar(Core, RayInfo, cuCMFD(tid), cuDevice(tid))
RayInfo should not be passed but the code ran without any error.
This is why cusparse routines failed; the preprocessing routine was behaving abnormally.
Unless you have an F90 interface (either explicit or implicitly created when used in a module), F77 calling conventions apply. With F77, no argument checking is done and it’s up to the programmer to ensure the call is correct.
-Mat
