compiled openmpi-1.2 with protalnd compilers (static version)
then when i try to compile HPL benchmark suite i get
make[2]: Entering directory `/share/apps/src/hpl/testing/ptest/Linux_PII_CBLAS’
/share/apps/pgi/linux86-64/7.0/bin/pgf77 -DHPL_CALL_CBLAS -I/share/apps/src/hpl/include -I/share/apps/src/hpl/include/Linux_PII_CBLAS -I/share/apps/openmpi-1.2_pgroup/include -Mnomain -o /share/apps/src/hpl/bin/Linux_PII_CBLAS/xhpl HPL_pddriver.o HPL_pdinfo.o HPL_pdtest.o /share/apps/src/hpl/lib/Linux_PII_CBLAS/libhpl.a /root/netlib/ARCHIVES/Linux_PII/libcblas.a /root/netlib/ARCHIVES/Linux_PII/libatlas.a /share/apps/openmpi-1.2_pgroup/lib/libmpich.a
/usr/bin/ld: /root/netlib/ARCHIVES/Linux_PII/libcblas.a: No such file: No such file or directory
i saw the reference to ‘multiple main’, is the the correct fix becuase it does not work with latest (eval) version of pgcc/pgf77.
-Henk
[root@swallowtail hpl]# tail -20 Make.Linux_PII_CBLAS
#CC = /usr/bin/gcc
CC = /share/apps/pgi/linux86-64/7.0/bin/pgcc
CCNOOPT = $(HPL_DEFS)
CCFLAGS = $(HPL_DEFS)
#CCFLAGS = $(HPL_DEFS) -fomit-frame-pointer -O3 -funroll-loops
On some platforms, it is necessary to use the Fortran linker to find
the Fortran internals used in the BLAS library.
#LINKER = /usr/bin/g77
LINKER = /share/apps/pgi/linux86-64/7.0/bin/pgf77
LINKFLAGS = $(CCFLAGS) -Mnomain
ARCHIVER = ar
ARFLAGS = r
RANLIB = echo
