I have a segfault problem with HPL-2.0 built by PGI 8.0-6, openmpi 1.4 and acml4.3.0.
Smaller size of matrix is OK, but HPL causes segfault for lager ones using more than 2GB/process.
Is this the limitation of HPL-2.0?
Anyway, please help me to solve this problem. I can send my Make.arch and HPL.dat to your specified mail address later.
Thank you, in advance.
Regards,
tmishima
P.S. for your information
The error is:
[node09:21940] *** Process received signal ***
[node09:21940] Signal: Segmentation fault (11)
[node09:21940] Signal code: Address not mapped (1)
[node09:21940] Failing at address: 0x2aaa35217088
[node09:21940] *** End of error message ***
ldd output is:
libmpi_f90.so.0 => /home/mishima/app/openmpi-pgi/lib/libmpi_f90.so.0 (0x00002b0dd4944000)
libmpi_f77.so.0 => /home/mishima/app/openmpi-pgi/lib/libmpi_f77.so.0 (0x00002b0dd4b47000)
libmpi.so.0 => /home/mishima/app/openmpi-pgi/lib/libmpi.so.0 (0x00002b0dd4d77000)
libopen-rte.so.0 => /home/mishima/app/openmpi-pgi/lib/libopen-rte.so.0 (0x00002b0dd5031000)
libopen-pal.so.0 => /home/mishima/app/openmpi-pgi/lib/libopen-pal.so.0 (0x00002b0dd527c000)
libdl.so.2 => /lib64/libdl.so.2 (0x0000003eeb400000)
libnsl.so.1 => /lib64/libnsl.so.1 (0x0000003ef3800000)
libutil.so.1 => /lib64/libutil.so.1 (0x0000003ef8a00000)
libpthread.so.0 => /lib64/libpthread.so.0 (0x0000003eeb800000)
libpgmp.so => /opt/pgi/linux86-64/8.0-6/libso/libpgmp.so (0x00002b0dd551a000)
libpgbind.so => /opt/pgi/linux86-64/8.0-6/libso/libpgbind.so (0x00002b0dd5644000)
libnuma.so.1 => /usr/lib64/libnuma.so.1 (0x0000003eea000000)
libpgf90.so => /opt/pgi/linux86-64/8.0-6/libso/libpgf90.so (0x00002b0dd5746000)
libpgf90_rpm1.so => /opt/pgi/linux86-64/8.0-6/libso/libpgf90_rpm1.so (0x00002b0dd5b02000)
libpgf902.so => /opt/pgi/linux86-64/8.0-6/libso/libpgf902.so (0x00002b0dd5c04000)
libpgf90rtl.so => /opt/pgi/linux86-64/8.0-6/libso/libpgf90rtl.so (0x00002b0dd5d17000)
libpgftnrtl.so => /opt/pgi/linux86-64/8.0-6/libso/libpgftnrtl.so (0x00002b0dd5e3a000)
libpgc.so => /opt/pgi/linux86-64/8.0-6/libso/libpgc.so (0x00002b0dd5f68000)
librt.so.1 => /lib64/librt.so.1 (0x0000003eef400000)
libm.so.6 => /lib64/libm.so.6 (0x0000003eeb000000)
libc.so.6 => /lib64/libc.so.6 (0x0000003eeac00000)
/lib64/ld-linux-x86-64.so.2 (0x0000003ee9c00000)
