Hi, I am combining the image from 2 cameras side by side to make a 200-degree view object detection system. I am using mobilenet-v2 but when I use hstack to combine the video array the AI doesn’t detect me unless I am 1 foot away from the camera.However, if I use vstack() it detects me 9 feet away. Any idea way???
import jetson.inference
import jetson.utils
import time
import cv2
import numpy as np
import math
import os
import pyttsx3
engine=pyttsx3.init()
engine.setProperty(‘rate’,150)
engine.setProperty(‘voice’,‘english+m1’)
text=‘initialising’
text1=’ Powering down’
engine.say(text)
engine.runAndWait()
timeStamp=time.time()
fpsFilt=0
reset=0
net=jetson.inference.detectNet(‘ssd-mobilenet-v2’,threshold=.5)
frame_counter=0
font=cv2.FONT_HERSHEY_SIMPLEX
print(cv2.version)
dispW=1280
dispH=720
dtav=0
cam0=cv2.VideoCapture(-1)
cam0.set(cv2.CAP_PROP_FRAME_WIDTH, dispW)
cam0.set(cv2.CAP_PROP_FRAME_HEIGHT, dispH)
cam1=cv2.VideoCapture(1)
cam1.set(cv2.CAP_PROP_FRAME_WIDTH, dispW)
cam1.set(cv2.CAP_PROP_FRAME_HEIGHT, dispH)
while True:
print(‘true’)
_,img0 = cam0.read()
_,img1 = cam1.read()
#img0=cv2.resize(img0,(1280,720))
#img1=cv2.resize(img1,(1280,720))
img=np.vstack((img0,img1))#<<<<<<<<<<<<<<<<<<<<<<<<<
height=img.shape[0]
width=img.shape[1]
frame=cv2.cvtColor(img,cv2.COLOR_BGR2RGBA).astype(np.float32)
frame=jetson.utils.cudaFromNumpy(frame)
detections=net.Detect(frame, width, height)
for detect in detections:
#print(detect)
ID=detect.ClassID
top=int(detect.Top)
left=int(detect.Left)
bottom=int(detect.Bottom)
right=int(detect.Right)
item=net.GetClassDesc(ID)
cv2.rectangle(img,(left,top),(right,bottom),(0,225,0),1)
cv2.putText(img,item,(left,top+20),font,.5,(0,255,0),2)
if item=='person':
print('person')
#display.RenderOnce(img,width,height)
dt=time.time()-timeStamp
fps=1/dt
fpsFilt=.9*fpsFilt + .1*fps
#print(str(round(fps,1))+' fps')
cv2.putText(img,str(round(fpsFilt,1))+' fps',(0,30),font,1,(0,0,255),2)
reset=reset+1
cv2.imshow('nanoCam',img)
if cv2.waitKey(1)==ord('q'):
break
cam1.release()
cam0.release()
cv2.destroyAllWindows()
