Please enable below variables, then you can get the latency for components and frame.
for frame
NVDS_ENABLE_LATENCY_MEASUREMENT
for components
NVDS_ENABLE_COMPONENT_LATENCY_MEASUREMENT
please noted you should use rtsp or live sources.
and which platform you running on? and how many sources input?
Can you provide the config you used? which version of DeepStream and which reference or sample app you are using?
Check sync = 0 for RTSP source
and this is the FAQ for rtsp latency
