Huge shared libraries size with PGI 17.10 on Debian Jessie
Dear PGI users and developers,
I am the developper of an open-source projet called TFEL that can be dowloaded here (to reproduce the issue):
https://github.com/thelfer/tfel
This project uses standard C++11 on CPU.
I used the following options:
pgc++-fast  -Minline -Mipa -DNDEBUG  -DNO_RUNTIME_CHECK_BOUNDS -Kieee -std=c++11
I noticed that the shared libraries produced by PGI are much greater in size than the ones generated by the other compilers (icpc,clang or gcc). A typical example, 139Mo vs 12Mo.
Is there a specific option to reduce this size ? Compared to the other compilers, I did not see any option to treat the visibility of symbols, does it exists ?
Thank you for your help,
Thomas Helfer
