Does HW & SW exist that supports multiple device programming of Jetson Nano/Xavier modules in a high volume manufacturing environment?
hello darryl.richter,
could you please describe the actual use-case,
when you mentioned programming, did you mean flashing the device with the release image, or programming the fuse?
Hello Jerry,
Thank you the response. I mean flashing the initial release image as well as programming the fuses. Probably separate workflows but both activities.
please check Secureboot chapter for the instructions to program the fuse.
developer guide also have a session for Flashing to Multiple Jetson Devices.
thanks
