I am trying to use the Hybrid (HYB) format in cuSPARSE for the first time.
I first need to convert a matrix from the CSR format to the HYB format, and then multiply a dense vector with the sparse matrix in the HYB format.
For this I am using the following three functions.
cusparseCreateHybMat
cusparseDcsr2hyb
cusparseDhybmv
Unfortunately, unlike the cuBLAS manual which tells the location (Host or Device) for each argument of each function, the cuSPARSE manual does not tell the location of the arguments for the functions in the library.
To start with I assumed that all the matrices and vectors are in the device memory, which compiled fine, but then gave segmentation fault during execution.
I tried various combinations of the memory locations for the three functions. Eventually, when I assumed that matrices in cusparseCreateHybMat and cusparseDcsr2hyb are in Host, and those in cusparseDhybmv are in Device, the code compiled fine and ran.
But, during execution, I am getting cusparseDcsr2hyb error “6”, which is then (I believe) leading to cusparseDhybmv error “7”.
The code is attached below.
Does anyone has experience with cusparseDcsr2hyb, and identify the problem in the code?
Thanks in advance.
Mahesh
module cusparse
use iso_c_binding
! enums
enum, bind© ! cusparseStatus_t
enumerator :: CUSPARSE_STATUS_SUCCESS=0
enumerator :: CUSPARSE_STATUS_NOT_INITIALIZED=1
enumerator :: CUSPARSE_STATUS_ALLOC_FAILED=2
enumerator :: CUSPARSE_STATUS_INVALID_VALUE=3
enumerator :: CUSPARSE_STATUS_ARCH_MISMATCH=4
enumerator :: CUSPARSE_STATUS_MAPPING_ERROR=5
enumerator :: CUSPARSE_STATUS_EXECUTION_FAILED=6
enumerator :: CUSPARSE_STATUS_INTERNAL_ERROR=7
enumerator :: CUSPARSE_STATUS_MATRIX_TYPE_NOT_SUPPORTED=8
end enum
enum, bind© ! cusparsePointerMode_t
enumerator :: CUSPARSE_POINTER_MODE_HOST = 0
enumerator :: CUSPARSE_POINTER_MODE_DEVICE = 1
end enum
enum, bind© ! cusparseAction_t
enumerator :: CUSPARSE_ACTION_SYMBOLIC = 0
enumerator :: CUSPARSE_ACTION_NUMERIC = 1
end enum
enum, bind© ! cusparseMatrixType_t
enumerator :: CUSPARSE_MATRIX_TYPE_GENERAL = 0
enumerator :: CUSPARSE_MATRIX_TYPE_SYMMETRIC = 1
enumerator :: CUSPARSE_MATRIX_TYPE_HERMITIAN = 2
enumerator :: CUSPARSE_MATRIX_TYPE_TRIANGULAR = 3
end enum
enum, bind© ! cusparseFillMode_t
enumerator :: CUSPARSE_FILL_MODE_LOWER = 0
enumerator :: CUSPARSE_FILL_MODE_UPPER = 1
end enum
enum, bind© ! cusparseDiagType_t
enumerator :: CUSPARSE_DIAG_TYPE_NON_UNIT = 0
enumerator :: CUSPARSE_DIAG_TYPE_UNIT = 1
end enum
enum, bind© ! cusparseIndexBase_t
enumerator :: CUSPARSE_INDEX_BASE_ZERO = 0
enumerator :: CUSPARSE_INDEX_BASE_ONE = 1
end enum
enum, bind© ! cusparseOperation_t
enumerator :: CUSPARSE_OPERATION_NON_TRANSPOSE = 0
enumerator :: CUSPARSE_OPERATION_TRANSPOSE = 1
enumerator :: CUSPARSE_OPERATION_CONJUGATE_TRANSPOSE = 2
end enum
enum, bind© ! cusparseDirection_t
enumerator :: CUSPARSE_DIRECTION_ROW = 0
enumerator :: CUSPARSE_DIRECTION_COLUMN = 1
end enum
enum, bind© ! cusparseHybPartition_t
enumerator :: CUSPARSE_HYB_PARTITION_AUTO = 0
enumerator :: CUSPARSE_HYB_PARTITION_USER = 1
enumerator :: CUSPARSE_HYB_PARTITION_MAX = 2
end enum
! types
type cusparseHandle
type(c_ptr) :: handle
end type cusparseHandle
type :: cusparseMatDescr
type(c_ptr) :: descr
end type cusparseMatDescr
type cusparseSolveAnalysisInfo
type(c_ptr) :: info
end type cusparseSolveAnalysisInfo
type cusparseHybMat
type(c_ptr) :: mat
end type cusparseHybMat
! helper functions
interface
integer(c_int) function cusparseCreate(handle) bind(C,name=‘cusparseCreate’)
import cusparseHandle
type(cusparseHandle) :: handle
end function cusparseCreate
end interface
interface
integer(c_int) function cusparseDestroy(handle) bind(C,name=‘cusparseDestroy’)
type(cusparseHandle), value :: handle
end function cusparseDestroy
end interface
interface
integer(c_int) function cusparseSetPointerMode(handle, mode) bind(C,name=‘cusparseSetPointerMode’)
use iso_c_binding
integer(c_int), value :: mode
end function cusparseSetPointerMode
end interface
! matrix descriptor
interface
integer(c_int) function cusparseCreateMatDescr(descrA) bind(C,name=‘cusparseCreateMatDescr’)
import cusparseMatDescr
type(cusparseMatDescr) :: descrA
end function cusparseCreateMatDescr
end interface
interface
integer(c_int) function cusparseDestroyMatDescr(descrA) bind(C,name=‘cusparseDestroyMatDescr’)
type(cusparseMatDescr), value :: descrA
end function cusparseDestroyMatDescr
end interface
interface
integer(c_int) function cusparseSetMatType(descrA, type) bind(C,name=‘cusparseSetMatType’)
use iso_c_binding
integer(c_int), value :: type
end function cusparseSetMatType
end interface
interface
integer(c_int) function cusparseSetMatIndexBase(descrA, base) bind(C,name=‘cusparseSetMatIndexBase’)
use iso_c_binding
integer(c_int), value :: base
end function cusparseSetMatIndexBase
end interface
interface cusparseCreateHybMat
integer(c_int) function cusparseCreateHybMat(hybmat) bind(C,name=‘cusparseCreateHybMat’)
import cusparseHybMat
type(cusparseHybMat) :: hybmat
end function cusparseCreateHybMat
end interface cusparseCreateHybMat
interface cusparseDhybmv
integer(c_int) function cusparseDhybmv(handle, trans, &
alpha, descr, hybA, x, beta, y) bind(C,name=‘cusparseDcsrmv’)
use iso_c_binding
import cusparseHandle, cusparseMatDescr, cusparseHybMat
integer(c_int), value :: trans
!pgi$ ignore_tkr (d) alpha, (d) beta
real(c_double) :: alpha
! type(cusparseMatDescr), value :: descr
integer(8), value :: descr
type(cusparseHybMat), device :: hybA
real(c_double), device :: x()
real(c_double) :: beta
real(c_double), device :: y()
end function cusparseDhybmv
end interface cusparseDhybmv
interface cusparseDcsr2hyb
integer(c_int) function cusparseDcsr2hyb(handle, m, n, &
descr, csrVal, csrRowPtr, csrColInd, hybmat, ellWidth, partType) bind(C,name=‘cusparseDcsr2hyb’)
use iso_c_binding
integer(c_int), value :: m, n
!type(cusparseMatDescr), value :: descr
real(c_double) :: csrVal()
integer(c_int) :: csrRowPtr()
integer(c_int) :: csrColInd(*)
integer(c_int), value :: ellWidth
integer(c_int), value :: partType
end function cusparseDcsr2hyb
end interface cusparseDcsr2hyb
end module cusparse
program hybmv
use cudafor
use cusparse
implicit none
real(8), dimension (:), allocatable :: bmat,x,y
integer, dimension (:), allocatable :: irstrt,icol
real(8), device, dimension (:), allocatable :: bmat_d,x_d,y_d
integer, device, dimension (:), allocatable :: irstrt_d,icol_d
integer :: istat, version
integer(8) :: iworkaround
type(cusparseHybMat) :: hybBmat
type(cusparseHybMat), device :: hybBmat_d
allocate (bmat(5),irstrt(4),icol(5),x(3),y(3))
allocate (bmat_d(5),irstrt_d(4),icol_d(5),x_d(3),y_d(3))
bmat = (/1.d0,1.d0,2.d0,1.0d0,2.d0/)
irstrt = (/1,2,4,6/)
icol = (/1,1,2,2,3/)
x = 1.0d0
y = 0.0d0
bmat_d = bmat
irstrt_d = irstrt
icol_d = icol
x_d = x
y_d = y
print *,"bmat "
print *,bmat
print *,"irstrt ",irstrt
print *,"icol ",icol
print *,"x "
print *,x
print *,“y original”
print *,y
istat = cusparseCreate(h)
if (istat /= CUSPARSE_STATUS_SUCCESS) write(,) ‘cusparseCreate error:’, istat
istat = cusparseCreateMatDescr(descrA)
if (istat /= CUSPARSE_STATUS_SUCCESS) write(,) ‘cusparseCreateMatDescr error:’, istat
istat = cusparseSetMatIndexBase(descrA, CUSPARSE_INDEX_BASE_ONE)
if (istat /= CUSPARSE_STATUS_SUCCESS) write(,) ‘cusparseSetMatIndexBase error:’, istat
istat = cusparseSetMatType(descrA, CUSPARSE_MATRIX_TYPE_GENERAL)
if (istat /= CUSPARSE_STATUS_SUCCESS) write(,) ‘cusparseSetMatType error:’, istat
istat = cusparseCreateHybMat(hybBmat)
if (istat /= CUSPARSE_STATUS_SUCCESS) write(,) ‘cusparseCreateHybMat error:’, istat
iworkaround = transfer(descrA,iworkaround)
istat = cusparseDcsr2hyb(h,3,3,iworkaround,bmat,irstrt,icol,hybBmat,1,CUSPARSE_HYB_PARTITION_AUTO)
if (istat /= CUSPARSE_STATUS_SUCCESS) write(,) ‘cusparseDcsr2hyb error:’, istat
hybBmat_d = HybBmat
istat = cusparseDhybmv(h,CUSPARSE_OPERATION_NON_TRANSPOSE,1.0d0,iworkaround, &
hybBmat_d,x_d,1.0d0,y_d)
if (istat /= CUSPARSE_STATUS_SUCCESS) write(,) ‘cusparseDhybmv error:’, istat
y = y_d
print *,“y new”
print *,y
deallocate(bmat,irstrt,icol,x,y)
deallocate(bmat_d,irstrt_d,icol_d,x_d,y_d)
istat = cusparseDestroyMatDescr(descrA)
istat = cusparseDestroy(h)
end program hybmv
