Hymba & Sana & ComfyUI
🚀 Big News for AI Enthusiasts! 🚀
We’re excited to share two groundbreaking updates in AI development and edge computing!
🎉 ComfyUI Now in Docker
Say goodbye to installation headaches! ComfyUI Docker now allows you to seamlessly install any node directly from the ComfyUI Manager. No need to worry about PyPI wheels anymore! Thanks to Docker’s integration, everything now points to https://pypi.jetson-ai-lab.dev/ @dusty’s wheels for smooth and efficient operation. Simplify your workflow and supercharge your creativity today! Docker
Get started and experience the ease of containerized AI tools.
🌟 Hymba & SANA on NVIDIA Jetson Orin
In another game-changing update, NVIDIA’s Hymba and SANA models are now running on the Jetson Orin platform!
  • Hymba: A hybrid-head architecture boosting the performance of small language models for edge devices. Docker
  • SANA: A text-to-image framework capable of generating ultra-high-resolution images efficiently, optimized for Jetson Orin’s advanced capabilities. Docker
This synergy delivers unprecedented power and efficiency for edge computing, enabling innovative applications in compact setups.
🎥 Stay tuned for an in-depth demonstration in our upcoming review of the Jetson Orin Super Nano Developer Kit—don’t miss it!
Learn more about Hymba’s transformative impact here: NVIDIA Developer Blog
The future of AI is here. Let’s build it together! 💡
I’m getting this error when trying to run the container.
Total VRAM 7620 MB, total RAM 7620 MB
pytorch version: 2.2.0
Set vram state to: NORMAL_VRAM
Device: cuda:0 Orin : cudaMallocAsync
/usr/local/lib/python3.10/dist-packages/transformers/utils/hub.py:127: FutureWarning: Using `TRANSFORMERS_CACHE` is deprecated and will be removed in v5 of Transformers. Use `HF_HOME` instead.
  warnings.warn(
Fatal Python error: Segmentation fault
Current thread 0x0000ffffb375a6c0 (most recent call first):
  Garbage-collecting
  File "/usr/lib/python3.10/sre_parse.py", line 167 in __getitem__
  File "/usr/lib/python3.10/sre_parse.py", line 665 in _parse
  File "/usr/lib/python3.10/sre_parse.py", line 444 in _parse_sub
  File "/usr/lib/python3.10/sre_parse.py", line 955 in parse
  File "/usr/lib/python3.10/sre_compile.py", line 788 in compile
  File "/usr/lib/python3.10/re.py", line 303 in _compile
  File "/usr/lib/python3.10/re.py", line 251 in compile
  File "/usr/local/lib/python3.10/dist-packages/google/protobuf/text_format.py", line 1300 in Tokenizer
  File "/usr/local/lib/python3.10/dist-packages/google/protobuf/text_format.py", line 1288 in <module>
  File "<frozen importlib._bootstrap>", line 241 in _call_with_frames_removed
  File "<frozen importlib._bootstrap_external>", line 883 in exec_module
  File "<frozen importlib._bootstrap>", line 688 in _load_unlocked
  File "<frozen importlib._bootstrap>", line 1006 in _find_and_load_unlocked
  File "<frozen importlib._bootstrap>", line 1027 in _find_and_load
  File "<frozen importlib._bootstrap>", line 1078 in _handle_fromlist
  File "/usr/local/lib/python3.10/dist-packages/google/protobuf/internal/python_message.py", line 38 in <module>
  File "/usr/local/lib/python3.10/dist-packages/google/protobuf/descriptor_pool.py", line 45 in <module>
  File "/usr/local/lib/python3.10/dist-packages/google/protobuf/message_factory.py", line 22 in <module>
  File "/usr/local/lib/python3.10/dist-packages/google/protobuf/json_format.py", line 31 in <module>
  File "/usr/local/lib/python3.10/dist-packages/onnx/serialization.py", line 16 in <module>
  File "/usr/local/lib/python3.10/dist-packages/onnx/__init__.py", line 76 in <module>
  File "/usr/local/lib/python3.10/dist-packages/torch/onnx/_internal/onnxruntime.py", line 34 in <module>
  File "/usr/local/lib/python3.10/dist-packages/torch/onnx/__init__.py", line 59 in <module>
  File "/usr/local/lib/python3.10/dist-packages/torchvision/ops/_register_onnx_ops.py", line 5 in <module>
  File "/usr/local/lib/python3.10/dist-packages/torchvision/ops/__init__.py", line 1 in <module>
  File "<frozen importlib._bootstrap>", line 992 in _find_and_load_unlocked
  File "/usr/local/lib/python3.10/dist-packages/torchvision/models/convnext.py", line 8 in <module>
  File "/usr/local/lib/python3.10/dist-packages/torchvision/models/__init__.py", line 2 in <module>
Extension modules: numpy.core._multiarray_umath, numpy.core._multiarray_tests, numpy.linalg._umath_linalg, numpy.fft._pocketfft_internal, numpy.random._common, numpy.random.bit_generator, numpy.random._bounded_integers, numpy.random._mt19937, numpy.random.mtrand, numpy.random._philox, numpy.random._pcg64, numpy.random._sfc64, numpy.random._generator, torch._C, torch._C._fft, torch._C._linalg, torch._C._nested, torch._C._nn, torch._C._sparse, torch._C._special, PIL._imaging, yaml._yaml, psutil._psutil_linux, psutil._psutil_posix, PIL._imagingft, charset_normalizer.md, requests.packages.charset_normalizer.md, requests.packages.chardet.md, google._upb._message (total: 29)
On Hymba container?
