Hyper-Q
Dear All
Could someone explain the difference of treatment the streams in a GPU with Hyper-Q (>= cap. 3.5) and without (< cap 3.5).
Is serial the execution inside each stream in both cases? Then if I have only kernels calls in the host I do not need synchronization inside each stream. Is that way?
Luis Gonçalves
All CUDA operations issued to a given stream are processed serially. This has no dependence on hyper-Q or compute capability. Hyper-Q makes it more likely that kernels from different streams can run concurrently, because it removes some artificial dependencies that may be introduced resulting from the single command queue of pre-cc3.5 devices.
This Question/Answer may be of interest:
http://stackoverflow.com/questions/23086767/what-is-advantage-of-hyper-q-of-gk110-over-concurrent-kernels-of-gk104-gf104-nvi
note the comments by Greg Smith.
How I program the concurrency (Depth first, Breadth first or Custom)?
