Thought I would share. Enjoy.
Traitlet Definition Change
import traitlets
from IPython.display import display
import ipywidgets.widgets as widgets
from jetbot import Camera, bgr8_to_jpeg
camera = Camera.instance(width=224, height=224)
image = widgets.Image(format=‘jpeg’, width=224, height=224)
blocked_slider = widgets.FloatSlider(description=‘blocked’, min=0.0, max=1.0, orientation=‘vertical’)
#DMF Added Next Line
gpu_slider = widgets.FloatSlider(description=“GPU%”, min=0.0, max=1.0, orientation=‘vertical’)
camera_link = traitlets.dlink((camera, ‘value’), (image, ‘value’), transform=bgr8_to_jpeg)
display(widgets.HBox([image, blocked_slider, gpu_slider]))
Traitlet Update Change
import torch.nn.functional as F
import time
#DMF Added gpu_usage() section
def gpu_usage():
“”"Gets the Jetson’s current GPU usage fraction
Returns:
float: The current GPU usage fraction.
with open('/sys/devices/gpu.0/load', 'r') as f:
return float(f.read().strip('\n')) / 1000.0
def update(change):
#DMF edited Next Line
global blocked_slider, gpu_slider, robot
x = change[‘new’]
x = preprocess(x)
y = model(x)
# we apply the `softmax` function to normalize the output vector so it sums to 1 (which makes it a probability distribution)
y = F.softmax(y, dim=1)
gpu_slider.value = gpu_usage()
prob_blocked = float(y.flatten()[0])
blocked_slider.value = prob_blocked
if prob_blocked < 0.4:
robot.forward(0.25)
else:
robot.left(0.15)
time.sleep(0.001)
update({‘new’: camera.value}) # we call the function once to intialize
robot.stop()
