I also meet this problem, have u slove it?
Continuing the discussion from Fail to use nvv4l2dec in ffmpeg:
The issue looks specific to certain h264 stream. You may try to decode other h264 streams to clarify this first. Besides, you can try to decode h264 stream through the samples:
/usr/src/jetson_multimedia_api/samples/00_video_decode/
/usr/src/jetson_multimedia_api/samples/unittest_samples/decoder_unit_sample/
I have solved this problem. The h264 stream from DJI H20T camera is BDR, so I need to transform it to IDR. The method of transform BDR H264 stream reference from here
【重磅干货】H264硬件解码Sample(基于妙算2-G)-开发者-大疆社区 (dji.com)
