“def osd_sink_pad_buffer_probe(pad, info, u_data):
GStreamer buffer probe for processing each frame.
Args:
pad: GStreamer pad
info: Buffer info
u_data: User data
Returns:
Gst.PadProbeReturn.OK: Probe result
global main_window, processed_object_ids, detection_counter, cumulative_obj_counter
import copy # Import copy for deep copying
if main_window is None:
logging.error("Main window reference not set")
return Gst.PadProbeReturn.OK
# Get detection confirmation count
detection_confirm_count = config['detection']['detection_confirm_count']
# Get buffer from pad
gst_buffer = info.get_buffer()
if not gst_buffer:
logging.error("Unable to get GstBuffer. Possible camera issue.")
# Get metadata from buffer
batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer))
if not batch_meta:
logging.debug("No metadata found in the current frame. Skipping frame.")
# Process each frame in the batch
l_frame = batch_meta.frame_meta_list
while l_frame is not None:
try:
except StopIteration:
logging.error("Error processing frame_meta")
break
frame_number = frame_meta.frame_num
n_frame_surface = pyds.get_nvds_buf_surface(hash(gst_buffer), frame_meta.batch_id)
# Create a deep copy of the frame image once - this is our fixed copy
fix_frame_image = copy.deepcopy(np.array(n_frame_surface, copy=True, order='C'))
fix_frame_image = cv2.cvtColor(fix_frame_image, cv2.COLOR_RGBA2BGR)
l_obj = frame_meta.obj_meta_list
# Initialize frame-specific data
fix_frame_class_ids = [] # Class IDs in this frame
fix_frame_masks = [] # Masks in this frame
fix_frame_bboxes = [] # Bounding boxes in this frame
frame_to_process = False # Flag to indicate if this frame needs processing
fix_real_world_pos = None # Real-world position for processing
image_h, image_w = fix_frame_image.shape[:2] # Get image dimensions
# Calculate overall bounding box that encompasses all objects in the frame
min_x, min_y = image_w, image_h
max_x, max_y = 0, 0
# First pass: collect all class IDs and masks for all objects and calculate overall bounding box
current_l_obj = l_obj
while current_l_obj is not None:
try:
obj_meta = pyds.NvDsObjectMeta.cast(current_l_obj.data)
break
obj_id = obj_meta.object_id
class_id = obj_meta.class_id
rect_params = obj_meta.rect_params
mask_params = obj_meta.mask_params
# Update overall bounding box
x1 = int(rect_params.left)
y1 = int(rect_params.top)
x2 = x1 + int(rect_params.width)
y2 = y1 + int(rect_params.height)
# Add class ID to frame's class IDs if not already there
if class_id not in fix_frame_class_ids:
fix_frame_class_ids.append(class_id)
# Extract and store mask
if mask_params and mask_params.data:
# Get the mask array and properly process it
mask = mask_params.get_mask_array()
mask = mask.reshape((mask_params.height, mask_params.width))
mask = (mask > 0).astype(np.uint8) * 255
# Store deep copies in our fixed arrays
fix_frame_masks.append(copy.deepcopy(mask))
fix_frame_bboxes.append(copy.deepcopy([x1, y1, x2, y2]))
else:
# Add empty mask
empty_mask = np.zeros((int(rect_params.height), int(rect_params.width)), dtype=np.uint8)
fix_frame_masks.append(copy.deepcopy(empty_mask))
fix_frame_bboxes.append(copy.deepcopy([]))
logging.debug(f"No mask data for object ID {obj_id}, class ID {class_id}")
# Only track objects with class IDs that aren't 0 or 1
if class_id not in [0, 1]:
# Track detection count
if obj_id not in detection_counter:
detection_counter[obj_id] = 1
else:
detection_counter[obj_id] += 1
# Check if this object's detection count matches the threshold
if detection_counter[obj_id] == detection_confirm_count and obj_id not in processed_object_ids:
# Mark for processing and save position data
frame_to_process = True
processed_object_ids.add(obj_id)
# Calculate real-world position
fix_real_world_pos, _ = calculate_real_world_position(
frame_meta.source_frame_width,
rect_params.left,
rect_params.width
# Move to next object
try:
current_l_obj = current_l_obj.next"
**• Hardware Platform : Jetson
**• DeepStream Version : 6.3
**• JetPack Version :5.1.2
*• TensorRT Version : 12
**• NVIDIA GPU Driver Version (valid for GPU only) : 535
**• Issue Type( questions, new requirements, bugs) : mask shift issue
