import jetson.inference
import jetson.utils
import numpy as np
import cv2
import argparse
import sys
# parse the command line
parser = argparse.ArgumentParser(description="Run pose estimation DNN on a video/image stream.",
formatter_class=argparse.RawTextHelpFormatter, epilog=jetson.inference.poseNet.Usage() +
jetson.utils.videoSource.Usage() + jetson.utils.videoOutput.Usage() + jetson.utils.logUsage())
parser.add_argument("input_URI", type=str, default="", nargs='?', help="URI of the input stream")
parser.add_argument("output_URI", type=str, default="", nargs='?', help="URI of the output stream")
parser.add_argument("--network", type=str, default="resnet18-body", help="pre-trained model to load (see below for options)")
parser.add_argument("--overlay", type=str, default="links,keypoints", help="pose overlay flags (e.g. --overlay=links,keypoints)\nvalid combinations are: 'links', 'keypoints', 'boxes', 'none'")
parser.add_argument("--threshold", type=float, default=0.15, help="minimum detection threshold to use")
try:
opt = parser.parse_known_args()[0]
except:
print("")
parser.print_help()
sys.exit(0)
# load the pose estimation model
net = jetson.inference.poseNet(opt.network, sys.argv, opt.threshold)
# create video sources & outputs
input = jetson.utils.videoSource(opt.input_URI, argv=sys.argv)
output = jetson.utils.videoOutput(opt.output_URI, argv=sys.argv)
img_size = (1920,1080)
skl = np.ones(img_size)
# process frames until the user exits
while True:
# capture the next image
img = input.Capture()
# perform pose estimation (with overlay)
poses = net.Process(img, overlay=opt.overlay)
print(opt.overlay)
# print the pose results
print("detected {:d} objects in image".format(len(poses)))
for pose in poses:
print(pose)
print(pose.Keypoints)
print('Links', pose.Links)
# find the keypoint index from the list of detected keypoints
# you can find these keypoint names in the model's JSON file,
# or with net.GetKeypointName() / net.GetNumKeypoints()
nose_idx = pose.FindKeypoint('nose')
left_eye_idx = pose.FindKeypoint('left_eye')
right_eye_idx = pose.FindKeypoint('right_eye')
left_ear_idx = pose.FindKeypoint('left_ear')
right_ear_idx = pose.FindKeypoint('right_ear')
left_shoulder_idx = pose.FindKeypoint('left_shoulder')
right_shoulder_idx = pose.FindKeypoint('right_shoulder')
left_elbow_idx = pose.FindKeypoint('left_elbow')
right_elbow_idx = pose.FindKeypoint('right_elbow')
left_wrist_idx = pose.FindKeypoint('left_wrist')
right_wrist_idx = pose.FindKeypoint('right_wrist')
left_hip_idx = pose.FindKeypoint('left_hip')
right_hip_idx = pose.FindKeypoint('right_hip')
left_knee_idx = pose.FindKeypoint('left_knee')
right_knee_idx = pose.FindKeypoint('right_knee')
left_ankle_idx = pose.FindKeypoint('left_ankle')
right_ankle_idx = pose.FindKeypoint('right_ankle')
neck_idx = pose.FindKeypoint('neck')
# if the keypoint index is < 0, it means it wasn't found in the image
if nose_idx < 0 or left_eye_idx < 0 or right_eye_idx < 0 or left_ear_idx < 0 or right_ear_idx < 0 or left_shoulder_idx < 0 or right_shoulder_idx < 0 or left_elbow_idx < 0 or right_elbow_idx < 0 or left_wrist_idx < 0 or right_wrist_idx < 0 or left_hip_idx < 0 or right_hip_idx < 0 or left_knee_idx < 0 or right_knee_idx < 0 or left_ankle_idx < 0 or right_ankle_idx < 0 or neck_idx < 0:
continue
nose = pose.Keypoint[nose_idx]
left_eye = pose.Keypoint(left_eye_idx)
right_eye = pose.Keypoint(right_eye_idx)
left_ear = pose.Keypoint(left_ear_idx)
right_ear = pose.Keypoint(right_ear_idx)
left_shoulder = pose.Keypoint(left_shoulder_idx)
right_shoulder = pose.Keypoint(right_shoulder_idx)
left_elbow = pose.Keypoint(left_elbow_idx)
right_elbow = pose.Keypoint(right_elbow_idx)
left_wrist = pose.Keypoint(left_wrist_idx)
right_wrist = pose.Keypoint(right_wrist_idx)
left_hip = pose.Keypoint(left_hip_idx)
right_hip = pose.Keypoint(right_hip_idx)
left_knee = pose.Keypoint(left_knee_idx)
right_knee = pose.Keypoint(right_knee_idx)
left_ankle = pose.Keypoint(left_ankle_idx)
right_ankle = pose.Keypoint(right_ankle_idx)
neck_idx = pose.Keypoint(neck_idx)
# shoulder
cv2.line(skl, (round(left_shoulder.x), round(left_shoulder.y) ),(round(right_shoulder.x), round(right_shoulder.y)), (0,0,0),10)
# hip
cv2.line(skl, (round(left_hip.x), round(left_hip.y) ),(round(right_hip.x), round(right_hip.y)), (0,0,0),10)
# left upper body
cv2.line(skl, (round(left_shoulder.x), round(left_shoulder.y) ),(round(left_hip.x), round(left_hip.y)), (0,0,0),10)
cv2.line(skl, (round(left_shoulder.x), round(left_shoulder.y) ),(round(left_elbow.x), round(left_elbow.y)), (0,0,0),10)
cv2.line(skl, (round(left_elbow.x), round(left_elbow.y) ),(round(left_wrist.x), round(left_wrist.y)), (0,0,0),10)
# right uppder body
cv2.line(skl, (round(right_shoulder.x), round(right_shoulder.y) ),(round(right_hip.x), round(right_hip.y)), (0,0,0),10)
cv2.line(skl, (round(right_shoulder.x), round(right_shoulder.y) ),(round(right_elbow.x), round(right_elbow.y)), (0,0,0),10)
cv2.line(skl, (round(right_elbow.x), round(right_elbow.y) ),(round(right_wrist.x), round(right_wrist.y)), (0,0,0),10)
# left leg
cv2.line(skl, (round(left_hip.x), round(left_hip.y) ),(round(left_knee.x), round(left_knee.y)), (0,0,0),10)
cv2.line(skl, (round(left_knee.x), round(left_knee.y) ),(round(left_ankle.x), round(left_ankle.y)), (0,0,0),10)
# right leg
cv2.line(skl, (round(right_hip.x), round(right_hip.y) ),(round(right_knee.x), round(right_knee.y)), (0,0,0),10)
cv2.line(skl, (round(right_knee.x), round(right_knee.y) ),(round(right_ankle.x), round(right_ankle.y)), (0,0,0),10)
# ḥead
# nek
# eyes
# nose
# mouth
cv2.imshow("foo",skl)
cv2.waitKey(0)
cv2.destroyAllWindows()
# render the image
output.Render(img)
# update the title bar
output.SetStatus("{:s} | Network {:.0f} FPS".format(opt.network, net.GetNetworkFPS()))
# print out performance info
net.PrintProfilerTimes()
# exit on input/output EOS
if not input.IsStreaming() or not output.IsStreaming():
break
If I tried t draw simple line it would work fine. I am not sure why when I run it it just retunr flat white images with no drawing.
But honestly I think this is done wrongly. Because what happen if i don’t have a point? it can’t be drawn.
