I am running test5 app inside docker, cant see engine file
i am running container , where is the engine file generated for secondary classifier, do i need to generate engine file outside docker then run it in inside container. I can see it is generating file but cant see engine inside docker conatiner and pipeline is stuck at 0 FPS.
If your model is uff or onnx format, you can set it directly (refer to nvinfer option uff-file or onnx-file), the engine file can be created automatically. Otherwise, you need to create the engine file and set it with the option model-engine-file.
• DeepStream Version
• TensorRT Version
able to built engine from onnx
thanks for the update. Is this still an DeepStream issue to support?
Issue solved
