#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <errno.h>
// the 4 directions for each 1 in the matrix
int dx[4] = { 0, 0, -1, 1 };
int dy[4] = { 1, -1, 0, 0 };
size_t cols, rows;
int** readmatrix(size_t* rows, size_t* cols, const char* filename,int number)
if (rows == NULL || cols == NULL || filename == NULL)
return NULL;
*rows = 0;
*cols = 0;
FILE* fp = fopen(filename, "r");
if (fp == NULL)
fprintf(stderr, "could not open %s: %s\n", filename, strerror(errno));
return NULL;
int** matrix = NULL, ** tmp;
char line[1024];
while (fgets(line, sizeof line, fp))
if (*cols == 0)
// determine the size of the columns based on
// the first row
char* scan = line;
int dummy;
int offset = 0;
while (sscanf(scan, "%d%n", &dummy, &offset) == 1)
scan += offset;
(*cols)++;
tmp = realloc(matrix, (*rows + 1) * sizeof * matrix);
if (tmp == NULL)
fclose(fp);
return matrix; // return all you've parsed so far
matrix = tmp;
matrix[*rows] = calloc(*cols, sizeof * matrix[*rows]);
if (matrix[*rows] == NULL)
fclose(fp);
if (*rows == 0) // failed in the first row, free everything
fclose(fp);
free(matrix);
return NULL;
int offset = 0;
char* scan = line;
for (size_t j = 0; j < *cols; ++j)
if (sscanf(scan, "%d%n", matrix[*rows] + j, &offset) == 1)
scan += offset;
else
matrix[*rows][j] = 0; // could not read, set cell to 0
// incrementing rows
(*rows)++;
fclose(fp);
if (*rows == number && *rows == cols)
return matrix;
else if (*rows >= number && number <= *cols)
*rows = number;
*cols = number;
int** tmp_matrix = malloc(sizeof(int*) * number);
for (int i = 0; i < number; ++i)
tmp_matrix[i] = malloc(sizeof(int) * number);
for (int i = 0; i < number; i++)
for (int j = 0; j < number; j++)
tmp_matrix[i][j] = matrix[i][j];
return tmp_matrix;
else
return matrix = NULL;
//DFS function to iterate through the matrix
void dfs(int** m, int** h, int x, int y, int c)
m[x][y] = c;
for (int i = 0; i < 4; i++)
int nx = x + dx[i], ny = y + dy[i];
if (nx < 0 || nx >= rows || ny < 0 || ny >= cols)
continue;
if (h[nx][ny] && !m[nx][ny])
dfs(m, h, nx, ny, c);
int main(int argc, char* argv[])
// input parameters
int nbrows = 0;
int set = 0;
char c[1000];
char k[1000];
int** w;
if (argc < 2)
printf("Input file:\n");
scanf("%s", &c);
printf("\nOutput file:\n");
scanf("%s", &k);
printf("\nMatrix size:\n");
scanf("%d", &nbrows);
else
strcpy(c, argv[1]);
strcpy(k, argv[2]);
nbrows = atoi(argv[3]);
if (!k)
printf("output file not found");
return 1;
if (!c)
printf("Input file not found");
return 1;
FILE* pf = fopen(&k, "w");
fprintf(pf, "Program description:\nThis program reads NxN binary matrix and find the connected components and label them using DFS (depth first search) .\n\n");
int** matrix = readmatrix(&rows, &cols, &c,nbrows);
if (rows == cols)
if (matrix == NULL)
fprintf(stderr, "could not read matrix\n");
return 1;
w = (int**)malloc(sizeof(int*) * rows);
for (int i = 0; i < rows; ++i)
w[i] = (int*)malloc(cols * sizeof(int));
for (int i = 0; i < rows; i++)
for (int j = 0; j < cols; j++)
w[i][j] = 0;
if (matrix[i][j] && !w[i][j])
dfs(w, matrix, i, j, ++set);
fprintf(pf, "Input:\n");
for (size_t i = 0; i < rows; ++i)
for (size_t j = 0; j < cols; ++j)
fprintf(pf,"%3d ", matrix[i][j]);
fprintf(pf,"\n");
fprintf(pf,"\nOutput:\n");
fprintf(pf,"%3d ", w[i][j]);
fprintf(pf, "\n");
// freeing memory
free(matrix[i]);
free(matrix);
free(w[i]);
free(w);
else
fprintf(pf, "Sorry!\nThis program for NxN matrix");
fclose(pf);
return 0;
please properly format code that you paste here. one simple way to do it:
- edit your post above by clicking on the pencil edit icon
- select all of your code
- click the
button at the top of the edit window - save your changes
This algorithm won’t be trivially convertible to a CUDA kernel. If you simply want connected component labelling in CUDA, you could use npp. Otherwise, if you want to write your own code to do it, I would suggest studying the literature. There are a number of papers that specifically describe a parallel approach and there is this
