I am troubleshooting an NVIDIA Jetson Orin NX SUPER installed on a Yahboom carrier board.
The system was previously working normally and booting Linux from an NVMe SSD. After a power outage, the Jetson started booting directly into the UEFI Interactive Shell instead of Linux.
I initially suspected the NVMe SSD. Checked the SSD and it was lost. However when i imaged a new ssd and tried again, same issue occured.,
Current symptoms:
- UEFI itself starts normally.
- UEFI version shown is 36.4.7.
- RAM is detected correctly.
- PCIe bridges and other PCIe devices are detected.
- The NVMe is not appearing as a boot device.
- map -r only shows FS0/FS1; there is no NVMe BLK/filesystem mapping.
Interestingly, when I initially ran pci, the NVMe controller was detected:
04 01 00 00 ==> Mass Storage Controller - Non-volatile memory subsystem
Vendor 10EC Device 5765
I then inspected the PCIe configuration for this device. The link showed:
Current Link Speed: 2.5 GT/s
Negotiated Link Width: x1
Data Link Layer Link Active: 0
After additional power cycles, the NVMe controller stopped appearing in pci altogether. The 04:00:00 NVIDIA PCIe bridge is still present, but the 04:01:00 NVMe endpoint is no longer enumerated.
I have tried:
- Completely powering off the Jetson.
- Reseating the original NVMe..
- Testing a second NVMe SSD.
- The second SSD produces the same behavior.
Therefore, I currently suspect a problem with the carrier-board M.2/PCIe path, rather than the SSD.
My questions are:
- Does this behavior suggest an M.2 power, PCIe reset, REFCLK, or PCIe signal problem on the Yahboom carrier?
- Is there a recommended way to check the M.2 3.3 V rail and PCIe signals on this carrier?
- Could the Data Link Layer Link Active = 0 indicate a PCIe hardware/link-training problem?
- Could a power outage cause this type of PCIe/NVMe failure?
- Would reflashing Jetson Linux/UEFI help in this situation, or should the PCIe hardware be diagnosed first?
- Is there a way to distinguish a Yahboom carrier-board fault from a damaged Orin NX module without having another carrier?
Any guidance on what to measure or check next would be greatly appreciated.
If you are talking about C4, there is a issue that got resolved recently.
→ overlay_pcie.tbz2
Hi Wayne, thanks for the quick reply.
Yes, this is C4 (the NVMe sits at bus 04 in the UEFI pci output).
One clarification, since I think my case may go beyond the intermittent issue:
- The failure started right after a power outage, which also killed the original SSD.
- Initially the NVMe endpoint (04:01:00, 10EC:5765) still appeared in pci, but the link was down (Data Link Layer Link Active = 0, 2.5 GT/s x1).
- After a few more power cycles, the endpoint no longer enumerates at all. Only the 04:00:00 bridge is present.
- This is now consistent on every cold boot, with two different SSDs.
My questions:
- Can the C4 issue fixed by overlay_pcie cause a consistent absence of the endpoint, or only intermittent failures?
- Does the overlay need to be applied at flash time (QSPI/UEFI update), and is it compatible with third-party carriers like Yahboom that use the Orin Nano devkit config?
- If the endpoint still does not enumerate after flashing 36.5 with the overlay, would you consider that confirmation of a carrier-board hardware fault (M.2 3.3 V rail, PERST#, or REFCLK)?
I will try 36.5 with the overlay in the meantime and report back.
The issue got fixed by the overlay is only for intermittent issue. It should work for all kinds of carrier board because the fix is in bpmp.
You need to clarify first if this is your first time using this carrier board as we don’t guarantee the functionality of a custom board.
Thanks for clarifying.
No, this is not a new setup. The same Orin NX Super and Yahboom carrier had been booting reliably from NVMe for 8 months before the power outage. No hardware or software changes were made before the failure.
So it sounds like the outage caused hardware damage rather than a bring-up or software issue. To isolate it without a spare carrier:
- Is there anything on the module side (e.g. the C4 root port or BPMP/UPHY state) that could be damaged or stuck after a power outage, and can it be checked from UEFI or Linux (booting from USB)?
- Are there UEFI or kernel logs that would show whether C4 fails at link training vs. PERST#/clock/power, to help narrow it down to the carrier?
I will measure the 3.3 V rail at the M.2 slot and also contact Yahboom about the carrier.
I think measuring the signal might be the option here. The log that a PCIe fails to enumerate something is quite simple that may not provide much helpful info.
Can this be the issue with the m2 slot only or with the whole carrier board. Has similar instances been reported regarding yahboom orin nx super?
You may check if anyone reported similar issue before. We don’t track the status of each custom board from different vendors.
As a workaround while I diagnose the M.2 slot, can I flash and boot the system from an SSD connected to the carrier’s USB port instead?
Yes, if USB is still working fine.
