Please provide the following information when creating a topic:
- Hardware Platform (GPU model and numbers): AWS
- System Memory
- Ubuntu Version
- NVIDIA GPU Driver Version (valid for GPU only)
- Issue Type( questions, new requirements, bugs): unable to tear down or reinstall the solution in aws platform. I choose g4e.48xlarge
- How to reproduce the issue ? (This is for bugs. Including the command line used and other details for reproducing) I got error with the
./envbuild.sh uninstall -f config.yml -c all
- Requirement details (This is for new requirement. Including the logs for the pods, the description for the pods):
ubuntu@ip-172-31-20-96:~/vss/dist$ ./envbuild.sh uninstall -f config.yml -c all
preparing artifacts
extracting inventory
cannot extract inventory when there are IaC changes
destroying TF shape
CTRL-C to abort
Acquiring state lock. This may take a few moments...
│ Error: Error acquiring the state lock
│ Error message: ConditionalCheckFailedException: The conditional request failed
│ Lock Info:
│ ID: c989f88c-fd2f-443d-435a-de0920513550
│ Path: vss-s3-us2/via-aws-cns-vss-deployment/terraform.tfstate
│ Operation: OperationTypeApply
│ Who: ubuntu@ip-172-31-20-96
│ Version: 1.5.7
│ Created: 2025-03-10 06:34:34.064354564 +0000 UTC
│ Info:
│ Terraform acquires a state lock to protect the state from being written
│ by multiple users at the same time. Please resolve the issue above and try
│ again. For most commands, you can disable locking with the "-lock=false"
│ flag, but this is not recommended.
