I can not flash Xavier on a Pegasus
when i access aurix serially via command line i got:
ERROR: SftyMon_IoHwAbs: Thermal Alert Triggered
INFO: SftyMon_IoHwAbs: Board Thermal Alert = HIGH
INFO: SftyMon_IoHwAbs: Board Thermal Shutdown = HIGH
INFO: SftyMon_IoHwAbs: Xavier A Thermal Alert = LOW
INFO: SftyMon_IoHwAbs: Xavier A Thermal Shutdown = HIGH
INFO: SftyMon_IoHwAbs: Xavier B Thermal Alert = HIGH
INFO: SftyMon_IoHwAbs: Xavier B Thermal Shutdown = HIGH
and this Error appears recursively. any explanation what does this error mean? by the way, i did simply try to poweroff the Pegasus some hours one day to cool it down. But i got the same issue! Is that a Hardwar issue? Thanks
Dear @medbelmkadem,
Could you check if the discussion in DRIVE AGX fail to power on frequently helps?
Hi, @medbelmkadem
This forum is for developers in NVIDIA DRIVE™ AGX SDK Developer Program. We will need you to use your account with corporate or university email address.
Or you can also change your current account to use corporate or university email address by following the below links:
My Profile | NVIDIA Developer → “Edit Profile” → “Change email” → “CHANGE”
Sorry for any inconvenience.
