I cannot get ACC ROUTINE to work
I’ve taken the laplace2d example problem from the NVIDIA repository and modified it in two ways:
  1. All of the data is in a module with an !$acc declare create, so the accelerator data should have global scope over the entire problem.
  2. The main routine does the data transfer to the accelerator, but the work is done in subroutine calls.
The compiler tells me the subroutine is accelerated:
bash-4.2$ /opt/pgi/20.4/linux86-64/20.4/bin/pgf90 -acc -ta=tesla:cc60 -Minfo=accel laplace2d5.f90
work:
14, Generating Tesla code
22, !$acc loop gang ! blockidx%x
24, !$acc loop worker, vector ! threadidx%y threadidx%x
31, !$acc loop gang ! blockidx%x
33, !$acc loop worker, vector ! threadidx%y threadidx%x
24, Loop is parallelizable
33, Loop is parallelizable
laplace:
72, Generating update device(a(:,:))
78, Generating update self(a(:,:))
bash-4.2$
The results are incorrect-- as though the data transfer in the main routine had not happened. I’m assuming I’m missing something in my routine declaration, but I have no idea what. Code follows:
module data_mod
integer, parameter :: fp_kind=kind(1.0)
integer, parameter :: n=4096, m=4096
integer :: i, j, iter
real(fp_kind), dimension (:,:), allocatable :: A, Anew
real(fp_kind), dimension (:), allocatable :: y0
real(fp_kind) :: pi=3.14159265
!$acc declare create(n, m, i, j, A, Anew, y0)
end module data_mod
subroutine work
use data_mod, only: fp_kind, n, m, i, j, A, Anew
!$acc routine gang device_type(acc_device_nvidia)
!$acc declare present(fp_kind, n, m, i, j, A, Anew)
!$acc loop
do j=1,m-2
!$acc loop
do i=1,n-2
Anew(i,j) = 0.25_fp_kind * ( A(i+1,j ) + A(i-1,j ) + &
A(i ,j-1) + A(i ,j+1) )
end do
end do
!$acc loop
do j=1,m-2
!$acc loop
do i=1,n-2
A(i,j) = Anew(i,j)
end do
end do
return
end subroutine work
program laplace
use data_mod, only: fp_kind, n, m, i, j, iter, A, Anew, &
& y0, pi
!$acc routine (work) gang
implicit none
real(fp_kind) :: start_time, stop_time
allocate ( A(0:n-1,0:m-1), Anew(0:n-1,0:m-1) )
allocate ( y0(0:m-1) )
A = 0.0_fp_kind
! Set B.C.
y0 = sin(pi* (/ (j,j=0,m-1) /) /(m-1))
A(0,:) = 0.0_fp_kind
A(n-1,:) = 0.0_fp_kind
Anew(0,1:m-1) = 0.0_fp_kind
Anew(n-1,1:m-1) = 0.0_fp_kind
A(:,0) = y0
A(:,m-1) = y0*exp(-pi)
Anew(1:n-1,0) = y0(i)
Anew(1:n-1,m-1) = y0(i)*exp(-pi)
write(*,’(a,i5,a,i5,a)’) ‘Jacobi relaxation Calculation:’, n, ’ x’, m, ’ mesh’
call cpu_time(start_time)
!$acc update device(A)
do iter = 1,1000
call work
end do
!$acc update self(A)
call cpu_time(stop_time)
write(*,’(a,f10.3,a)’) ’ completed in ‘, stop_time-start_time, ’ seconds’
WRITE(*,’(10F6.3)’) ((A(I,J),J=0,9),I=0,n-1,n/16)
deallocate (A,Anew,y0)
end program laplace
Hi chasmotron,
The problem here is that you’re not calling the device routine, you’re calling the host routine, so nothing is running on the device. A device routine must be called from within a compute region or another device routine.
You had some other issues as well:
  1. Parameters shouldn’t be put in a data clause since they have no storage. The parameter basically just gets replaced by the literal value. It wont cause an error, just a warning.
  2. Putting variables in data regions (declare in this case) will make the variable shared by all threads. This is fine for the arrays since each thread only accesses a single element, but is problematic for the i and j scalars since this would be a race condition. Best to make these local variables and the compiler will make private copies for each thread.
With these changes, the GPU time is 0.655 seconds on my V100 vs 19.66 on a single Skylake core.
% cat laplace.f90
module data_mod
!$acc declare create(A, Anew, y0)
end module data_mod
subroutine work
use data_mod, only: fp_kind, n, m, A, Anew
integer :: i, j
!$acc routine gang
!$acc loop
do j=1,m-2
!$acc loop
do i=1,n-2
end do
end do
!$acc loop
do j=1,m-2
!$acc loop
do i=1,n-2
A(i,j) = Anew(i,j)
end do
end do
return
end subroutine work
program laplace
use data_mod, only: fp_kind, n, m, A, Anew, &
& y0, pi
implicit none
integer iter, i, j
A = 0.0_fp_kind
! Set B.C.
A(:,0) = y0
write(*,'(a,i5,a,i5,a)') 'Jacobi relaxation Calculation:', n, ' x', m, ' mesh'
do iter = 1,1000
!$acc parallel num_gangs(m-2)
call work
!$acc end parallel
end do
write(*,'(a,f10.3,a)') ' completed in ', stop_time-start_time, ' seconds'
WRITE(*,'(10F6.3)') ((A(I,J),J=0,9),I=0,n-1,n/16)
end program laplace
% pgfortran laplace.f90 -V20.4 -fast -o cpu.out
% pgfortran laplace.f90 -V20.4 -fast -ta=tesla -Minfo=accel -o acc.out
work:
     19, Loop is parallelizable
     20, Loop is parallelizable
         19, !$acc loop gang, vector(4) ! blockidx%y threadidx%y
         20, !$acc loop gang, vector(32) ! blockidx%x threadidx%x
     26, Loop is parallelizable
     27, Loop is parallelizable
         26, !$acc loop gang, vector(4) ! blockidx%y threadidx%y
         27, !$acc loop gang, vector(32) ! blockidx%x threadidx%x
laplace:
     66, Generating update device(a(:,:))
     70, Generating update self(a(:,:))
% ./cpu.out
Jacobi relaxation Calculation: 4096 x 4096 mesh
 completed in     19.666 seconds
 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000
 0.195 0.188 0.181 0.174 0.167 0.161 0.154 0.147 0.141 0.134
 0.383 0.369 0.355 0.342 0.328 0.315 0.302 0.289 0.276 0.263
 0.556 0.536 0.516 0.496 0.477 0.457 0.438 0.419 0.400 0.382
 0.707 0.682 0.657 0.632 0.607 0.582 0.558 0.533 0.510 0.486
 0.832 0.802 0.772 0.743 0.714 0.684 0.656 0.627 0.599 0.572
 0.924 0.891 0.858 0.825 0.793 0.761 0.729 0.697 0.666 0.635
 0.981 0.946 0.911 0.876 0.842 0.807 0.773 0.740 0.707 0.674
 1.000 0.964 0.929 0.893 0.858 0.823 0.788 0.754 0.721 0.687
 0.981 0.946 0.911 0.876 0.841 0.807 0.773 0.740 0.707 0.674
 0.924 0.891 0.858 0.825 0.793 0.760 0.728 0.697 0.666 0.635
 0.831 0.802 0.772 0.742 0.713 0.684 0.655 0.627 0.599 0.571
 0.707 0.681 0.656 0.631 0.606 0.582 0.557 0.533 0.509 0.486
 0.555 0.535 0.515 0.496 0.476 0.457 0.438 0.419 0.400 0.382
 0.382 0.368 0.355 0.341 0.328 0.314 0.301 0.288 0.275 0.263
 0.194 0.187 0.181 0.174 0.167 0.160 0.153 0.147 0.140 0.134
% acc.out
 completed in      0.606 seconds
Note that you’ll be better off putting the compute regions inside of work, rather than using a gang routine since the compiler has more information about how to schedule the kernel. You’ll see that I had to add to add a “num_gangs” clause in the above example, since the runtime doesn’t know how big the i loop is outside of the routine.
Here’s the same code but using a kernel region inside the work routine.
% cat laplace.2.f90
module data_mod
end module data_mod
subroutine work
integer :: i, j
!$acc kernels
do j=1,m-2
do i=1,n-2
end do
end do
do j=1,m-2
do i=1,n-2
A(i,j) = Anew(i,j)
end do
end do
!$acc end kernels
return
end subroutine work
program laplace
& y0, pi
implicit none
integer iter, i, j
A = 0.0_fp_kind
! Set B.C.
A(:,0) = y0
do iter = 1,1000
call work
end do
end program laplace
% pgfortran laplace.2.f90 -V20.4 -fast -ta=tesla -Minfo=accel -o acc2.out
work:
laplace:
% ./acc2.out
 completed in      0.455 seconds
Hope this helps,
Mat
Mat,
Thank you so much for taking the time to help me out. It is very much appreciated!
