Nothing I try is working. Have Drive, i set up admin account, enabled sharing. What am I missing? Drive Crashes after the failed login and the credentials and user are never correct even tho they are. Tried cleaning up the launcher, installing it fresh. Tried turning the pc on and off after Drive install.
Hello @melita.nikol! I am going to pass this along to the dev team. In the meantime, have you tried using the password “admin”?
Can you attach a copy of your logs found here: C:\Users\<USERNAME>\.nvidia-omniverse\logs\launcher
