Recently I followed this article to add the cuda.rules…
and then I can’t stop the program at the breakpoint …
Before adding the rules , I didn’t change any VC enviroment parameters
and it could be interrupted…
what’s wrong with my VC 2005?
please~help me~~ External Image
hello~kyzhao
I have installed the “VS2005 Project Wizard for CUDA” you supported…
and I used it to create a new project…
But I still can not debug on EmuRelease or EmuDebug…
In VS environment , about the option “Custom Build Rules”
I can find 2 CUDA options :
path : VCProjectDefaults\cuda.rules (kyzhao supported I think…)
path : NVIDIA CUDA SDK\common\scripts\nvcc.rules
(CUDA SDK supported)
(1)
when I enable cuda.rules to compile…
The VS couldn’t compile all instruction about CUDA
and couldn’t find the “cutil.h”…
(2)when I enable cuda.rules to compile…
The VS “can” compile the cu file…but EmuRelease or EmuDebug is
still useless
How can I set my VS 2005 environment parameters and
make it normal…
Thanks ~kyzhao
I enabled the VCProjectDefaults\cuda.rules to compile…
and followed the step you said…
But it still couldn’t stop the program at the break point…
I guess something wrong with my setting in VS 2005 before…
I didn’t use the visual assist…
so I can’t follow the step you said on your web…
