Hi!
I bought a new laptop, DELL Inspiron 15 7000 Gaming and I can’t enable the HDMI output.
Any help is welcome
INFO:
Opensuse Leap 42.3 (clean install)
Plasma: 5.8.7
Kernel: 4.4.79-19-default
Video: Intel / Nvidia 1050 Ti (4GB)
/var/log/Xorg.0.log
xrandr -q
xrandr: Failed to get size of gamma for output default
Screen 0: minimum 1920 x 1080, current 1920 x 1080, maximum 1920 x 1080
default connected primary 1920x1080+0+0 0mm x 0mm
1920x1080 77.00*
lspci | egrep ‘VGA|3D’
00:02.0 VGA compatible controller: Intel Corporation Device 591b (rev 04)
01:00.0 VGA compatible controller: NVIDIA Corporation Device 1c8c (rev ff)
systemctl status bumblebeed
● bumblebeed.service - Bumblebee C Daemon
Loaded: loaded (/usr/lib/systemd/system/bumblebeed.service; enabled; vendor preset: disabled)
Active: active (running) since lun 2017-08-21 02:21:53 -05; 13min ago
Main PID: 1337 (bumblebeed)
Tasks: 1 (limit: 512)
CGroup: /system.slice/bumblebeed.service
└─1337 /usr/sbin/bumblebeed
ago 21 02:21:53 linux-r6jt systemd[1]: Started Bumblebee C Daemon.
ago 21 02:21:53 linux-r6jt bumblebeed[1337]: [ 8.699982] [INFO]/usr/sbin/bumblebeed 3.2.1 started
zypper lr -d
# | Alias | Nombre | Habilitado | Comprobación GPG | Actualizar | Prioridad | Tipo | URI | Servicio
1 | bumblebee | bumblebee | Si | (r ) Si | Si | 80 | rpm-md | http://download.opensuse.org/repositories/X11:/Bumblebee/openSUSE_Leap_42.3/ |
2 | openSUSE-Leap-42.3-0 | openSUSE-Leap-42.3-0 | No | ---- | ---- | 99 | yast2 | hd:///?device=/dev/disk/by-id/usb-hp_v245o_070D59582459A246-0:0-part2 |
3 | packman | packman | Si | (r ) Si | Si | 70 | rpm-md | http://ftp.gwdg.de/pub/linux/misc/packman/suse/openSUSE_Leap_42.3/ |
4 | repo-debug | openSUSE-Leap-42.3-Debug | No | ---- | ---- | 99 | NONE | http://download.opensuse.org/debug/distribution/leap/42.3/repo/oss/ |
5 | repo-debug-non-oss | openSUSE-Leap-42.3-Debug-Non-Oss | No | ---- | ---- | 99 | NONE | http://download.opensuse.org/debug/distribution/leap/42.3/repo/non-oss/ |
6 | repo-debug-update | openSUSE-Leap-42.3-Update-Debug | No | ---- | ---- | 99 | NONE | http://download.opensuse.org/debug/update/leap/42.3/oss/ |
7 | repo-debug-update-non-oss | openSUSE-Leap-42.3-Update-Debug-Non-Oss | No | ---- | ---- | 99 | NONE | http://download.opensuse.org/debug/update/leap/42.3/non-oss/ |
8 | repo-non-oss | openSUSE-Leap-42.3-Non-Oss | Si | (r ) Si | Si | 99 | yast2 | http://download.opensuse.org/distribution/leap/42.3/repo/non-oss/ |
9 | repo-oss | openSUSE-Leap-42.3-Oss | Si | (r ) Si | Si | 99 | yast2 | http://download.opensuse.org/distribution/leap/42.3/repo/oss/ |
10 | repo-source | openSUSE-Leap-42.3-Source | No | ---- | ---- | 99 | NONE | http://download.opensuse.org/source/distribution/leap/42.3/repo/oss/ |
11 | repo-source-non-oss | openSUSE-Leap-42.3-Source-Non-Oss | No | ---- | ---- | 99 | NONE | http://download.opensuse.org/source/distribution/leap/42.3/repo/non-oss/ |
12 | repo-update | openSUSE-Leap-42.3-Update | Si | (r ) Si | Si | 99 | rpm-md | http://download.opensuse.org/update/leap/42.3/oss/ |
13 | repo-update-non-oss | openSUSE-Leap-42.3-Update-Non-Oss | Si | (r ) Si | Si | 99 | rpm-md | http://download.opensuse.org/update/leap/42.3/non-oss/ |
rpm -qa | grep kernel
kernel-default-4.4.76-1.1.x86_64
kernel-source-4.4.79-19.1.noarch
patterns-openSUSE-devel_kernel-20170518-6.1.x86_64
kernel-firmware-20170530-9.1.noarch
kernel-devel-4.4.79-19.1.noarch
kernel-default-4.4.79-19.1.x86_64
kernel-default-devel-4.4.79-19.1.x86_64
kernel-syms-4.4.79-19.1.x86_64
kernel-macros-4.4.79-19.1.noarch
rpm -qa | grep nvidia
nvidia-bumblebee-32bit-375.66-1.1.x86_64
nvidia-bumblebee-375.66-1.1.x86_64
glxspheres
Polygons in scene: 62464 (61 spheres * 1024 polys/spheres)
Visual ID of window: 0x1a4
Context is Direct
OpenGL Renderer: Gallium 0.4 on llvmpipe (LLVM 3.8, 256 bits)
34.686275 frames/sec - 38.709883 Mpixels/sec
34.755700 frames/sec - 38.787361 Mpixels/sec
36.524304 frames/sec - 40.761123 Mpixels/sec
36.885706 frames/sec - 41.164448 Mpixels/sec
35.982285 frames/sec - 40.156230 Mpixels/sec
35.188890 frames/sec - 39.270801 Mpixels/sec
37.165416 frames/sec - 41.476604 Mpixels/sec
36.637231 frames/sec - 40.887150 Mpixels/sec
optirun glxspheres
Visual ID of window: 0x21
Context is Direct
OpenGL Renderer: GeForce GTX 1050 Ti/PCIe/SSE2
187.472601 frames/sec - 209.219422 Mpixels/sec
189.738145 frames/sec - 211.747770 Mpixels/sec
180.724968 frames/sec - 201.689064 Mpixels/sec
188.873463 frames/sec - 210.782785 Mpixels/sec
185.966571 frames/sec - 207.538693 Mpixels/sec
188.303382 frames/sec - 210.146575 Mpixels/sec
184.786172 frames/sec - 206.221368 Mpixels/sec
179.954157 frames/sec - 200.828839 Mpixels/sec
optirun nvidia-smi
Mon Aug 21 22:19:12 2017
| NVIDIA-SMI 375.66 Driver Version: 375.66 |
| 0 GeForce GTX 105... Off | 0000:01:00.0 Off | N/A |
| N/A 45C P0 N/A / N/A | 6MiB / 4038MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 4450 G Xorg 6MiB |
Also, when I run: optirun nvidia-xconfig --query-gpu-info
with the HDMI cable (my TV):
Number of GPUs: 1
GPU #0:
Name : GeForce GTX 1050 Ti
UUID : GPU-045745ff-d31d-e9da-b426-e5d4f2748786
PCI BusID : PCI:1:0:0
Number of Display Devices: 1
Display Device 0 (TV-0):
EDID Name : SAMSUNG
Minimum HorizSync : 15.000 kHz
Maximum HorizSync : 81.000 kHz
Minimum VertRefresh : 24 Hz
Maximum VertRefresh : 75 Hz
Maximum PixelClock : 594.000 MHz
Maximum Width : 4096 pixels
Maximum Height : 2160 pixels
Preferred Width : 3840 pixels
Preferred Height : 2160 pixels
Preferred VertRefresh : 30 Hz
Physical Width : 890 mm
Physical Height : 500 mm
without the HDMI cable (only the laptop screen):
Number of GPUs: 1
GPU #0:
Number of Display Devices: 0
