Hello, I am starting to use the jetson nano for a project but I have a startup problem.
When I want to install the operating system for the first time I get a message on the monitor which indicates the following “Not Optimun Mode Recommended Mode: 1024x768 60 Hz” also does not recognize my keyboard or mouse. I’ve been trying to fix this for days but still can’t. I have followed the steps published on the official page but I don’t know what the problem is.
I would be very grateful if you help me solve this problem.
Welcome to the NVIDIA Developer forums! You issue needs to be posted in the Jetson Nano category for support visibility. I will move it over for you now.
I am trying to do it, but in the step 3 in the flashing it stays at 99%. I am installing jetpack 4.6, also i tried with jetpack 4.6.2 but i have the same problem.
I finally managed to install the operating system. I don’t know what happened but I tried again and it worked. I used jetpack4.5.1. Thank you very much for your help, you saved me!!
