Hi!
I can’t install python “scikit-image” lib on nvidia jetson nano r32.3.1. I get the following error: “error: command ‘aarch64-linux-gnu-gcc’ failed with exit status 1”.
We are checking this issue.
Will update a detail step with you later.
The same questions, it conducts on Jeston Nano, and only shows the errors of installing imagecodes.
Please kindly check.
jet@jet-desktop:/usr/src/cudnn_samples_v7/mnistCUDNN$ sudo pip3 install scikit-image
WARNING: The directory ‘/home/jet/.cache/pip’ or its parent directory is not owned or is not writable by the current user. The cache has been disabled. Check the permissions and owner of that directory. If executing pip with sudo, you may want sudo’s -H flag.
Collecting scikit-image
Downloading scikit-image-0.17.2.tar.gz (29.8 MB)
|████████████████████████████████| 29.8 MB 1.6 MB/s
Collecting PyWavelets>=1.1.1
Downloading PyWavelets-1.1.1.tar.gz (4.6 MB)
|████████████████████████████████| 4.6 MB 3.5 MB/s
Collecting imageio>=2.3.0
Downloading imageio-2.8.0-py3-none-any.whl (3.3 MB)
|████████████████████████████████| 3.3 MB 4.3 MB/s
Requirement already satisfied: matplotlib!=3.0.0,>=2.0.0 in /usr/lib/python3/dist-packages (from scikit-image) (2.1.1)
Collecting networkx>=2.0
Downloading networkx-2.4-py3-none-any.whl (1.6 MB)
|████████████████████████████████| 1.6 MB 4.2 MB/s
Requirement already satisfied: numpy>=1.15.1 in /usr/local/lib/python3.6/dist-packages (from scikit-image) (1.18.4)
Requirement already satisfied: pillow!=7.1.0,!=7.1.1,>=4.3.0 in /usr/lib/python3/dist-packages (from scikit-image) (5.1.0)
Requirement already satisfied: scipy>=1.0.1 in /usr/local/lib/python3.6/dist-packages (from scikit-image) (1.4.1)
Collecting tifffile>=2019.7.26
Downloading tifffile-2020.5.11-py3-none-any.whl (132 kB)
|████████████████████████████████| 132 kB 4.0 MB/s
Collecting decorator>=4.3.0
Downloading decorator-4.4.2-py2.py3-none-any.whl (9.2 kB)
Collecting imagecodecs>=2020.2.18
Downloading imagecodecs-2020.2.18.tar.gz (8.8 MB)
|████████████████████████████████| 8.8 MB 2.8 MB/s
Building wheels for collected packages: scikit-image, PyWavelets, imagecodecs
Building wheel for scikit-image (setup.py) … done
Created wheel for scikit-image: filename=scikit_image-0.17.2-cp36-cp36m-linux_aarch64.whl size=24840165 sha256=064fa678a85f4f15ebea9a6525ef2e34cdcd8fce27e599ffcd9debcef60f3b33
Stored in directory: /tmp/pip-ephem-wheel-cache-rh3uiq0v/wheels/95/df/81/38e2d698d8c3605baff734ff6a1fe1c277e920f5fd0bd0b29d
Building wheel for PyWavelets (setup.py) … done
Created wheel for PyWavelets: filename=PyWavelets-1.1.1-cp36-cp36m-linux_aarch64.whl size=5714778 sha256=e033f87ca6d0efe7893493aa39ba8eff7acfdaad05eae97bf005802c95e021c8
Stored in directory: /tmp/pip-ephem-wheel-cache-rh3uiq0v/wheels/77/30/86/528105a88c8ae72ca512f1b1ea8dc4ccaab8ea4b38513e1c52
Building wheel for imagecodecs (setup.py) … error
ERROR: Command errored out with exit status 1:
command: /usr/bin/python3 -u -c ‘import sys, setuptools, tokenize; sys.argv[0] = ‘"’"’/tmp/pip-install-uf6adwmi/imagecodecs/setup.py’“'”‘; file=’“'”‘/tmp/pip-install-uf6adwmi/imagecodecs/setup.py’“'”‘;f=getattr(tokenize, ‘"’“‘open’”’“‘, open)(file);code=f.read().replace(’”‘"’\r\n’“'”‘, ‘"’"’\n’“'”‘);f.close();exec(compile(code, file, ‘"’“‘exec’”’"‘))’ bdist_wheel -d /tmp/pip-wheel-8zu2hfts
cwd: /tmp/pip-install-uf6adwmi/imagecodecs/
Complete output (328 lines):
running bdist_wheel
running build
running build_py
creating build
creating build/lib.linux-aarch64-3.6
creating build/lib.linux-aarch64-3.6/imagecodecs
copying imagecodecs/imagecodecs.py → build/lib.linux-aarch64-3.6/imagecodecs
copying imagecodecs/main.py → build/lib.linux-aarch64-3.6/imagecodecs
copying imagecodecs/_imagecodecs.py → build/lib.linux-aarch64-3.6/imagecodecs
copying imagecodecs/init.py → build/lib.linux-aarch64-3.6/imagecodecs
creating build/lib.linux-aarch64-3.6/imagecodecs/licenses
copying imagecodecs/licenses/LICENSE-libjpeg-turbo → build/lib.linux-aarch64-3.6/imagecodecs/licenses
copying imagecodecs/licenses/LICENSE-lcms2 → build/lib.linux-aarch64-3.6/imagecodecs/licenses
copying imagecodecs/licenses/LICENSE-liblzma → build/lib.linux-aarch64-3.6/imagecodecs/licenses
copying imagecodecs/licenses/LICENSE-snappy → build/lib.linux-aarch64-3.6/imagecodecs/licenses
copying imagecodecs/licenses/LICENSE-charls → build/lib.linux-aarch64-3.6/imagecodecs/licenses
copying imagecodecs/licenses/LICENSE-bitshuffle → build/lib.linux-aarch64-3.6/imagecodecs/licenses
copying imagecodecs/licenses/LICENSE-brotli → build/lib.linux-aarch64-3.6/imagecodecs/licenses
copying imagecodecs/licenses/LICENSE-brunsli → build/lib.linux-aarch64-3.6/imagecodecs/licenses
copying imagecodecs/licenses/LICENSE-libpng → build/lib.linux-aarch64-3.6/imagecodecs/licenses
copying imagecodecs/licenses/LICENSE-jpg_0xc3 → build/lib.linux-aarch64-3.6/imagecodecs/licenses
copying imagecodecs/licenses/LICENSE-zopfli → build/lib.linux-aarch64-3.6/imagecodecs/licenses
copying imagecodecs/licenses/LICENSE-jpeg → build/lib.linux-aarch64-3.6/imagecodecs/licenses
copying imagecodecs/licenses/LICENSE-bzip2 → build/lib.linux-aarch64-3.6/imagecodecs/licenses
copying imagecodecs/licenses/LICENSE-zstd → build/lib.linux-aarch64-3.6/imagecodecs/licenses
copying imagecodecs/licenses/LICENSE-libaec → build/lib.linux-aarch64-3.6/imagecodecs/licenses
copying imagecodecs/licenses/LICENSE-blosc → build/lib.linux-aarch64-3.6/imagecodecs/licenses
copying imagecodecs/licenses/LICENSE-jxrlib → build/lib.linux-aarch64-3.6/imagecodecs/licenses
copying imagecodecs/licenses/LICENSE-fastlz → build/lib.linux-aarch64-3.6/imagecodecs/licenses
copying imagecodecs/licenses/LICENSE-zfp → build/lib.linux-aarch64-3.6/imagecodecs/licenses
copying imagecodecs/licenses/LICENSE-libwebp → build/lib.linux-aarch64-3.6/imagecodecs/licenses
copying imagecodecs/licenses/LICENSE-giflib → build/lib.linux-aarch64-3.6/imagecodecs/licenses
copying imagecodecs/licenses/LICENSE-lz4 → build/lib.linux-aarch64-3.6/imagecodecs/licenses
copying imagecodecs/licenses/LICENSE-lzf → build/lib.linux-aarch64-3.6/imagecodecs/licenses
copying imagecodecs/licenses/LICENSE-zlib → build/lib.linux-aarch64-3.6/imagecodecs/licenses
copying imagecodecs/licenses/LICENSE-libtiff → build/lib.linux-aarch64-3.6/imagecodecs/licenses
copying imagecodecs/licenses/LICENSE-libmng → build/lib.linux-aarch64-3.6/imagecodecs/licenses
copying imagecodecs/licenses/LICENSE-openjpeg → build/lib.linux-aarch64-3.6/imagecodecs/licenses
running build_ext
skipping ‘imagecodecs/_aec.c’ Cython extension (up-to-date)
skipping ‘imagecodecs/_bitshuffle.c’ Cython extension (up-to-date)
skipping ‘imagecodecs/_blosc.c’ Cython extension (up-to-date)
skipping ‘imagecodecs/_brotli.c’ Cython extension (up-to-date)
skipping ‘imagecodecs/_bz2.c’ Cython extension (up-to-date)
skipping ‘imagecodecs/_gif.c’ Cython extension (up-to-date)
skipping ‘imagecodecs/_imcd.c’ Cython extension (up-to-date)
skipping ‘imagecodecs/_jpeg2k.c’ Cython extension (up-to-date)
skipping ‘imagecodecs/_jpeg8.c’ Cython extension (up-to-date)
skipping ‘imagecodecs/_jpegsof3.c’ Cython extension (up-to-date)
skipping ‘imagecodecs/_jpegxr.c’ Cython extension (up-to-date)
skipping ‘imagecodecs/_lz4.c’ Cython extension (up-to-date)
skipping ‘imagecodecs/_lzf.c’ Cython extension (up-to-date)
skipping ‘imagecodecs/_lzma.c’ Cython extension (up-to-date)
skipping ‘imagecodecs/_png.c’ Cython extension (up-to-date)
skipping ‘imagecodecs/_shared.c’ Cython extension (up-to-date)
skipping ‘imagecodecs/_snappy.c’ Cython extension (up-to-date)
skipping ‘imagecodecs/_tiff.c’ Cython extension (up-to-date)
skipping ‘imagecodecs/_webp.c’ Cython extension (up-to-date)
skipping ‘imagecodecs/_zlib.c’ Cython extension (up-to-date)
skipping ‘imagecodecs/_zopfli.c’ Cython extension (up-to-date)
skipping ‘imagecodecs/_zstd.c’ Cython extension (up-to-date)
building ‘imagecodecs._aec’ extension
creating build/temp.linux-aarch64-3.6
creating build/temp.linux-aarch64-3.6/imagecodecs
aarch64-linux-gnu-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -Iimagecodecs -I/usr/include/python3.6m -I/usr/local/lib/python3.6/dist-packages/numpy/core/include -c imagecodecs/_aec.c -o build/temp.linux-aarch64-3.6/imagecodecs/_aec.o
In file included from /usr/include/python3.6m/numpy/ndarraytypes.h:1809:0,
from /usr/include/python3.6m/numpy/ndarrayobject.h:18,
from /usr/include/python3.6m/numpy/arrayobject.h:4,
from imagecodecs/_aec.c:598:
/usr/include/python3.6m/numpy/npy_1_7_deprecated_api.h:15:2: warning: #warning "Using deprecated NumPy API, disable it by " “#defining NPY_NO_DEPRECATED_API NPY_1_7_API_VERSION” [-Wcpp]
aarch64-linux-gnu-gcc -pthread -shared -Wl,-O1 -Wl,-Bsymbolic-functions -Wl,-Bsymbolic-functions -Wl,-z,relro -Wl,-Bsymbolic-functions -Wl,-z,relro -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 build/temp.linux-aarch64-3.6/imagecodecs/_aec.o -lm -laec -o build/lib.linux-aarch64-3.6/imagecodecs/_aec.cpython-36m-aarch64-linux-gnu.so
building ‘imagecodecs._bitshuffle’ extension
creating build/temp.linux-aarch64-3.6/bitshuffle-0.3.5
aarch64-linux-gnu-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -Iimagecodecs -Ibitshuffle-0.3.5 -I/usr/include/python3.6m -I/usr/local/lib/python3.6/dist-packages/numpy/core/include -c imagecodecs/_bitshuffle.c -o build/temp.linux-aarch64-3.6/imagecodecs/_bitshuffle.o
from imagecodecs/_bitshuffle.c:598:
aarch64-linux-gnu-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -Iimagecodecs -Ibitshuffle-0.3.5 -I/usr/include/python3.6m -I/usr/local/lib/python3.6/dist-packages/numpy/core/include -c bitshuffle-0.3.5/bitshuffle_core.c -o build/temp.linux-aarch64-3.6/bitshuffle-0.3.5/bitshuffle_core.o
bitshuffle-0.3.5/bitshuffle_core.c: In function ‘bshuf_trans_byte_elem_NEON_16’:
bitshuffle-0.3.5/bitshuffle_core.c:391:23: warning: pointer targets in passing argument 1 of ‘vld1q_s8’ differ in signedness [-Wpointer-sign]
a0 = vld1q_s8(in_b + 2ii + 016);
In file included from bitshuffle-0.3.5/bitshuffle_core.c:37:0:
/usr/lib/gcc/aarch64-linux-gnu/7/include/arm_neon.h:17197:1: note: expected ‘const int8_t * {aka const signed char *}’ but argument is of type ‘const char ’
vld1q_s8 (const int8_t a)
bitshuffle-0.3.5/bitshuffle_core.c:392:23: warning: pointer targets in passing argument 1 of ‘vld1q_s8’ differ in signedness [-Wpointer-sign]
b0 = vld1q_s8(in_b + 2ii + 116);
/usr/lib/gcc/aarch64-linux-gnu/7/include/arm_neon.h:17197:1: note: expected ‘const int8_t * {aka const signed char *}’ but argument is of type ‘const char *’
bitshuffle-0.3.5/bitshuffle_core.c:406:18: warning: pointer targets in passing argument 1 of ‘vst1q_s8’ differ in signedness [-Wpointer-sign]
vst1q_s8(out_b + 0size + ii, a0);
/usr/lib/gcc/aarch64-linux-gnu/7/include/arm_neon.h:26906:1: note: expected ‘int8_t * {aka signed char *}’ but argument is of type ‘char *’
vst1q_s8 (int8_t a, int8x16_t b)
bitshuffle-0.3.5/bitshuffle_core.c:407:18: warning: pointer targets in passing argument 1 of ‘vst1q_s8’ differ in signedness [-Wpointer-sign]
vst1q_s8(out_b + 1size + ii, b0);
/usr/lib/gcc/aarch64-linux-gnu/7/include/arm_neon.h:26906:1: note: expected ‘int8_t * {aka signed char *}’ but argument is of type ‘char ’
bitshuffle-0.3.5/bitshuffle_core.c: In function ‘bshuf_trans_byte_elem_NEON_32’:
bitshuffle-0.3.5/bitshuffle_core.c:427:23: warning: pointer targets in passing argument 1 of ‘vld1q_s8’ differ in signedness [-Wpointer-sign]
a0 = vld1q_s8(in_b + 4ii + 016);
bitshuffle-0.3.5/bitshuffle_core.c:428:23: warning: pointer targets in passing argument 1 of ‘vld1q_s8’ differ in signedness [-Wpointer-sign]
b0 = vld1q_s8(in_b + 4ii + 116);
bitshuffle-0.3.5/bitshuffle_core.c:429:23: warning: pointer targets in passing argument 1 of ‘vld1q_s8’ differ in signedness [-Wpointer-sign]
c0 = vld1q_s8(in_b + 4ii + 216);
bitshuffle-0.3.5/bitshuffle_core.c:430:23: warning: pointer targets in passing argument 1 of ‘vld1q_s8’ differ in signedness [-Wpointer-sign]
d0 = vld1q_s8(in_b + 4ii + 316);
bitshuffle-0.3.5/bitshuffle_core.c: In function ‘bshuf_trans_byte_elem_NEON_64’:
bitshuffle-0.3.5/bitshuffle_core.c:473:23: warning: pointer targets in passing argument 1 of ‘vld1q_s8’ differ in signedness [-Wpointer-sign]
a0 = vld1q_s8(in_b + 8ii + 016);
bitshuffle-0.3.5/bitshuffle_core.c:474:23: warning: pointer targets in passing argument 1 of ‘vld1q_s8’ differ in signedness [-Wpointer-sign]
b0 = vld1q_s8(in_b + 8ii + 116);
bitshuffle-0.3.5/bitshuffle_core.c:475:23: warning: pointer targets in passing argument 1 of ‘vld1q_s8’ differ in signedness [-Wpointer-sign]
c0 = vld1q_s8(in_b + 8ii + 216);
bitshuffle-0.3.5/bitshuffle_core.c:476:23: warning: pointer targets in passing argument 1 of ‘vld1q_s8’ differ in signedness [-Wpointer-sign]
d0 = vld1q_s8(in_b + 8ii + 316);
bitshuffle-0.3.5/bitshuffle_core.c:477:23: warning: pointer targets in passing argument 1 of ‘vld1q_s8’ differ in signedness [-Wpointer-sign]
e0 = vld1q_s8(in_b + 8ii + 416);
bitshuffle-0.3.5/bitshuffle_core.c:478:23: warning: pointer targets in passing argument 1 of ‘vld1q_s8’ differ in signedness [-Wpointer-sign]
f0 = vld1q_s8(in_b + 8ii + 516);
bitshuffle-0.3.5/bitshuffle_core.c:479:23: warning: pointer targets in passing argument 1 of ‘vld1q_s8’ differ in signedness [-Wpointer-sign]
g0 = vld1q_s8(in_b + 8ii + 616);
bitshuffle-0.3.5/bitshuffle_core.c:480:23: warning: pointer targets in passing argument 1 of ‘vld1q_s8’ differ in signedness [-Wpointer-sign]
h0 = vld1q_s8(in_b + 8ii + 716);
bitshuffle-0.3.5/bitshuffle_core.c:518:18: warning: pointer targets in passing argument 1 of ‘vst1q_s8’ differ in signedness [-Wpointer-sign]
bitshuffle-0.3.5/bitshuffle_core.c:519:18: warning: pointer targets in passing argument 1 of ‘vst1q_s8’ differ in signedness [-Wpointer-sign]
bitshuffle-0.3.5/bitshuffle_core.c:520:18: warning: pointer targets in passing argument 1 of ‘vst1q_s8’ differ in signedness [-Wpointer-sign]
vst1q_s8(out_b + 2size + ii, c0);
bitshuffle-0.3.5/bitshuffle_core.c:521:18: warning: pointer targets in passing argument 1 of ‘vst1q_s8’ differ in signedness [-Wpointer-sign]
vst1q_s8(out_b + 3size + ii, d0);
bitshuffle-0.3.5/bitshuffle_core.c:522:18: warning: pointer targets in passing argument 1 of ‘vst1q_s8’ differ in signedness [-Wpointer-sign]
vst1q_s8(out_b + 4size + ii, e0);
bitshuffle-0.3.5/bitshuffle_core.c:523:18: warning: pointer targets in passing argument 1 of ‘vst1q_s8’ differ in signedness [-Wpointer-sign]
vst1q_s8(out_b + 5size + ii, f0);
bitshuffle-0.3.5/bitshuffle_core.c:524:18: warning: pointer targets in passing argument 1 of ‘vst1q_s8’ differ in signedness [-Wpointer-sign]
vst1q_s8(out_b + 6size + ii, g0);
bitshuffle-0.3.5/bitshuffle_core.c:525:18: warning: pointer targets in passing argument 1 of ‘vst1q_s8’ differ in signedness [-Wpointer-sign]
vst1q_s8(out_b + 7size + ii, h0);
vst1q_s8 (int8_t *a, int8x16_t b)
bitshuffle-0.3.5/bitshuffle_core.c: In function ‘bshuf_trans_byte_bitrow_NEON’:
bitshuffle-0.3.5/bitshuffle_core.c:683:27: warning: pointer targets in passing argument 1 of ‘vld1q_s8’ differ in signedness [-Wpointer-sign]
a0 = vld1q_s8(in_b + (ii + 0)*nbyte_row + jj);
vld1q_s8 (const int8_t *a)
bitshuffle-0.3.5/bitshuffle_core.c:684:27: warning: pointer targets in passing argument 1 of ‘vld1q_s8’ differ in signedness [-Wpointer-sign]
b0 = vld1q_s8(in_b + (ii + 1)*nbyte_row + jj);
bitshuffle-0.3.5/bitshuffle_core.c:685:27: warning: pointer targets in passing argument 1 of ‘vld1q_s8’ differ in signedness [-Wpointer-sign]
c0 = vld1q_s8(in_b + (ii + 2)*nbyte_row + jj);
bitshuffle-0.3.5/bitshuffle_core.c:686:27: warning: pointer targets in passing argument 1 of ‘vld1q_s8’ differ in signedness [-Wpointer-sign]
d0 = vld1q_s8(in_b + (ii + 3)*nbyte_row + jj);
bitshuffle-0.3.5/bitshuffle_core.c:687:27: warning: pointer targets in passing argument 1 of ‘vld1q_s8’ differ in signedness [-Wpointer-sign]
e0 = vld1q_s8(in_b + (ii + 4)*nbyte_row + jj);
bitshuffle-0.3.5/bitshuffle_core.c:688:27: warning: pointer targets in passing argument 1 of ‘vld1q_s8’ differ in signedness [-Wpointer-sign]
f0 = vld1q_s8(in_b + (ii + 5)*nbyte_row + jj);
bitshuffle-0.3.5/bitshuffle_core.c:689:27: warning: pointer targets in passing argument 1 of ‘vld1q_s8’ differ in signedness [-Wpointer-sign]
g0 = vld1q_s8(in_b + (ii + 6)*nbyte_row + jj);
bitshuffle-0.3.5/bitshuffle_core.c:690:27: warning: pointer targets in passing argument 1 of ‘vld1q_s8’ differ in signedness [-Wpointer-sign]
h0 = vld1q_s8(in_b + (ii + 7)*nbyte_row + jj);
aarch64-linux-gnu-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -Iimagecodecs -Ibitshuffle-0.3.5 -I/usr/include/python3.6m -I/usr/local/lib/python3.6/dist-packages/numpy/core/include -c bitshuffle-0.3.5/iochain.c -o build/temp.linux-aarch64-3.6/bitshuffle-0.3.5/iochain.o
aarch64-linux-gnu-gcc -pthread -shared -Wl,-O1 -Wl,-Bsymbolic-functions -Wl,-Bsymbolic-functions -Wl,-z,relro -Wl,-Bsymbolic-functions -Wl,-z,relro -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 build/temp.linux-aarch64-3.6/imagecodecs/_bitshuffle.o build/temp.linux-aarch64-3.6/bitshuffle-0.3.5/bitshuffle_core.o build/temp.linux-aarch64-3.6/bitshuffle-0.3.5/iochain.o -lm -o build/lib.linux-aarch64-3.6/imagecodecs/_bitshuffle.cpython-36m-aarch64-linux-gnu.so
building ‘imagecodecs._blosc’ extension
aarch64-linux-gnu-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -Iimagecodecs -I/usr/include/python3.6m -I/usr/local/lib/python3.6/dist-packages/numpy/core/include -c imagecodecs/_blosc.c -o build/temp.linux-aarch64-3.6/imagecodecs/_blosc.o
from imagecodecs/_blosc.c:598:
imagecodecs/_blosc.c:602:10: fatal error: blosc.h: No such file or directory
#include “blosc.h”
compilation terminated.
ERROR: Failed building wheel for imagecodecs
Running setup.py clean for imagecodecs
Successfully built scikit-image PyWavelets
Failed to build imagecodecs
Installing collected packages: PyWavelets, imageio, decorator, networkx, imagecodecs, tifffile, scikit-image
Attempting uninstall: decorator
Found existing installation: decorator 4.1.2
Uninstalling decorator-4.1.2:
Successfully uninstalled decorator-4.1.2
Running setup.py install for imagecodecs … error
command: /usr/bin/python3 -u -c ‘import sys, setuptools, tokenize; sys.argv[0] = ‘"’"’/tmp/pip-install-uf6adwmi/imagecodecs/setup.py’“'”‘; file=’“'”‘/tmp/pip-install-uf6adwmi/imagecodecs/setup.py’“'”‘;f=getattr(tokenize, ‘"’“‘open’”’“‘, open)(file);code=f.read().replace(’”‘"’\r\n’“'”‘, ‘"’"’\n’“'”‘);f.close();exec(compile(code, file, ‘"’“‘exec’”’“‘))’ install --record /tmp/pip-record-ioo5rlfp/install-record.txt --single-version-externally-managed --compile --install-headers /usr/local/include/python3.6/imagecodecs
running install
running build
running build_py
creating build
running build_ext
/usr/include/python3.6m/numpy/npy_1_7_deprecated_api.h:15:2: warning: #warning “Using deprecated NumPy API, disable it by " “#defining NPY_NO_DEPRECATED_API NPY_1_7_API_VERSION” [-Wcpp]
#include “blosc.h”
ERROR: Command errored out with exit status 1: /usr/bin/python3 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '”'”‘/tmp/pip-install-uf6adwmi/imagecodecs/setup.py’”'”‘; file=’”'”‘/tmp/pip-install-uf6adwmi/imagecodecs/setup.py’”‘"’;f=getattr(tokenize, ‘"’“‘open’”‘"’, open)(file);code=f.read().replace(‘"’“‘\r\n’”‘"’, ‘"’“‘\n’”‘"’);f.close();exec(compile(code, file, ‘"’“‘exec’”‘"’))’ install --record /tmp/pip-record-ioo5rlfp/install-record.txt --single-version-externally-managed --compile --install-headers /usr/local/include/python3.6/imagecodecs Check the logs for full command output.
To install latest scikit-image, please check this comment:
