When I command:
docker pull nvcr.io/nvidia/tritonserver:23.05-py3
I got
Error response from daemon: received unexpected HTTP status: 502 Bad Gateway
Is there somthing wrong?
Thank you.
When I command:
I got
Thank you.
me too it isn’t working
yes, me too. i think today all of images from NGC can’t pull. actually the problem when try to login nvcr.io
Cannot pull any image from nvcr.io (502) - NGC GPU Cloud / Docker and NVIDIA Docker - NVIDIA Developer Forums
Cannot pull trsenorRT image from NGC. received unexpected HTTP status: 502 Bad Gateway - NGC GPU Cloud / Docker and NVIDIA Docker - NVIDIA Developer Forums
yes, I also encountered similar situations problem with:
Username: $oauthtoken
Password:
Error response from daemon: login attempt to https://nvcr.io/v2/ failed with status: 502 Bad Gateway
I have informed the team that manages the site.
Please stand by as we work to resolve this.
Thanks for your patience.
Tom
Hi everyone,
This issue was resolved Tuesday 6/20, at 15:23 PDT.
We are sorry for the inconvenience.
Tom
Yes, I’ve also run into problems with similar circumstances:
Password: $oauthtoken
Password:
Daemon error response: unsuccessful login attempt with status: 502 Poor Gateway.
Hi @ma7403595,
This may be related to a known bug in the API. The workaround is to downgrade to CLI version 3.22.0. You can downgrade from the CLI, the command is ngc version upgrade 3.22.0
This issue will be fixed soon.
