jia@ubuntu:~$ deepstream-app --version-all
deepstream-app version 6.1.1
DeepStreamSDK 6.1.1
CUDA Driver Version: 11.4
CUDA Runtime Version: 11.4
TensorRT Version: 8.4
cuDNN Version: 8.4
libNVWarp360 Version: 2.0.1d3
jia@ubuntu:~/deepstream/deepstream_python_apps-master/apps/deepstream-rtsp-in-rtsp-out$ python3 deepstream_test1_rtsp_in_rtsp_out.py -i rtsp://admin:Jia420418@192.168.1.64:8554/ds-test -g nvinfer
Creating Pipeline
Creating streamux
Creating source_bin 0
Creating source bin
source-bin-00
Creating Pgie
Creating tiler
Creating nvvidconv
Creating nvosd
Creating H264 Encoder
Creating H264 rtppay
Adding elements to Pipeline
*** DeepStream: Launched RTSP Streaming at rtsp://localhost:8554/ds-test ***
Starting pipeline
Opening in BLOCKING MODE
0:00:00.238813236 8239 0x10171d00 WARN nvinfer gstnvinfer.cpp:643:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::initialize() <nvdsinfer_context_impl.cpp:1170> [UID = 1]: Warning, OpenCV has been deprecated. Using NMS for clustering instead of cv::groupRectangles with topK = 20 and NMS Threshold = 0.5
WARNING: Deserialize engine failed because file path: /home/jia/deepstream/deepstream_python_apps-master/apps/deepstream-rtsp-in-rtsp-out/…/…/…/…/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine open error
0:00:04.129882452 8239 0x10171d00 WARN nvinfer gstnvinfer.cpp:643:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1897> [UID = 1]: deserialize engine from file :/home/jia/deepstream/deepstream_python_apps-master/apps/deepstream-rtsp-in-rtsp-out/…/…/…/…/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine failed
0:00:04.298716768 8239 0x10171d00 WARN nvinfer gstnvinfer.cpp:643:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2002> [UID = 1]: deserialize backend context from engine from file :/home/jia/deepstream/deepstream_python_apps-master/apps/deepstream-rtsp-in-rtsp-out/…/…/…/…/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine failed, try rebuild
0:00:04.298781473 8239 0x10171d00 INFO nvinfer gstnvinfer.cpp:646:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1923> [UID = 1]: Trying to create engine from model files
WARNING: [TRT]: The implicit batch dimension mode has been deprecated. Please create the network with NetworkDefinitionCreationFlag::kEXPLICIT_BATCH flag whenever possible.
ERROR: Cannot access prototxt file ‘/home/jia/deepstream/deepstream_python_apps-master/apps/deepstream-rtsp-in-rtsp-out/…/…/…/…/samples/models/Primary_Detector/resnet10.prototxt’
ERROR: failed to build network since parsing model errors.
ERROR: failed to build network.
0:00:07.361595174 8239 0x10171d00 ERROR nvinfer gstnvinfer.cpp:640:gst_nvinfer_logger: NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1943> [UID = 1]: build engine file failed
0:00:07.527076249 8239 0x10171d00 ERROR nvinfer gstnvinfer.cpp:640:gst_nvinfer_logger: NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2029> [UID = 1]: build backend context failed
0:00:07.527131225 8239 0x10171d00 ERROR nvinfer gstnvinfer.cpp:640:gst_nvinfer_logger: NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::initialize() <nvdsinfer_context_impl.cpp:1266> [UID = 1]: generate backend failed, check config file settings
0:00:07.527187194 8239 0x10171d00 WARN nvinfer gstnvinfer.cpp:846:gst_nvinfer_start: error: Failed to create NvDsInferContext instance
0:00:07.527201210 8239 0x10171d00 WARN nvinfer gstnvinfer.cpp:846:gst_nvinfer_start: error: Config file path: dstest1_pgie_config.txt, NvDsInfer Error: NVDSINFER_CONFIG_FAILED
Error: gst-resource-error-quark: Failed to create NvDsInferContext instance (1): /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvinfer/gstnvinfer.cpp(846): gst_nvinfer_start (): /GstPipeline:pipeline0/GstNvInfer:primary-inference:
