I can't see my audio files
During the process of loading audio, the audio is not visible in the folder.
(I used a translator. Sorry if the sentence is strange.)
that’s actually the folder wherein the audio files are located. it’s the next field Track Name where you specify the actual audio clip in the dropdown menu.
Thank you. Solved. I put the address of the folder in the track root path.
