I chanced jetson nano kernel name
hi,
I changed the kernel name while trying to solve a problem.
in this way:
cd ~/
sudo mv /lib/modules/4.9.140-tegra/ /lib/modules/4.9.140
sudo reboot
and of course it resulted in a bigger error. jetson nano won’t open.
How i solve this problem? Thank you.
You probably should not copy from a different build to a new build unless the configuration of the new build is basically the same as the old build.
Sounds like you replaced “/boot/Image”, and this has (A) an incorrect configuration, and/or (B) new “uname -r” (due to changed “CONFIG_LOCALVERSION”). Is this an eMMC model or SD card model? If SD card model, then you should be able to fix this when the SD card is on your Linux host PC. If an eMMC model, then you’ll need to clone, fix the clone, and then reflash.
