I could not run any of the tutorials on jetson AI lab with jetpack 6.1 r36.4
Hello All,
I have a Jetson Orin NX running the Jetpack 6.1 image with r36.4.
The following are some tutorials that I have tried on AI lab:
LLaVa Live : failed, could not find or build the container.
nanoSam: failed, could not find or build the container.
sam: failed, could not find or build the container.
nanoOwl: last step of the docker failed at step 5/6
efficientvit: failed, could not find or build the container.
am I doing something wrong?
If there is one out there: could someone give a more detailed tutorial on how to run of the examples listed above? I would really appreciate it. Thank you!
Our team is updating the container for JetPack 6.1.
You can find some r36.4 images already. For example:
https://hub.docker.com/r/dustynv/nano_llm/tags
Thank you for the update!! I appreciate your efforts!!
