I went through the setup process, I believe it created it, but how I would check that and find the name?
I tried again thinking I did something wrong, and tells me workstation2023 is already installed (or something like that).
Thanks,
Thanks,
What OS are you installing Nucleus?
You can validate what version of a server you installed through Launcher
The hamburger menu → settings will take you to the system monitor so you can validate all the services are running
Lastly, you can add your localhost server to Navigator if it was not added automatically Connect to a Server
Make sure you log into the server (it’s possible you may need the admin:admin user)
I had figured this out from reading another post. I think it is just localhost, but I had been trying https://localhost.
