I fond that if I change the location in the pipline of the two plugin in the deepstream-app.c . It can be work. the newplugin named “fenceplugin”, It must be ahead of dsexample.
The code about function of “create_pipeline” as below:
gboolean
create_pipeline (AppCtx * appCtx,
bbox_generated_callback bbox_generated_post_analytics_cb,
bbox_generated_callback all_bbox_generated_cb, perf_callback perf_cb,
overlay_graphics_callback overlay_graphics_cb)
gboolean ret = FALSE;
NvDsPipeline *pipeline = &appCtx->pipeline;
NvDsConfig *config = &appCtx->config;
GstBus *bus;
GstElement *last_elem;
GstElement *tmp_elem1;
GstElement *tmp_elem2;
guint i;
GstPad *fps_pad = NULL;
gulong latency_probe_id;
_dsmeta_quark = g_quark_from_static_string (NVDS_META_STRING);
appCtx->all_bbox_generated_cb = all_bbox_generated_cb;
appCtx->bbox_generated_post_analytics_cb = bbox_generated_post_analytics_cb;
appCtx->overlay_graphics_cb = overlay_graphics_cb;
if (config->osd_config.num_out_buffers < 8) {
config->osd_config.num_out_buffers = 8;
pipeline->pipeline = gst_pipeline_new (“pipeline”);
if (!pipeline->pipeline) {
NVGSTDS_ERR_MSG_V (“Failed to create pipeline”);
goto done;
bus = gst_pipeline_get_bus (GST_PIPELINE (pipeline->pipeline));
pipeline->bus_id = gst_bus_add_watch (bus, bus_callback, appCtx);
gst_object_unref (bus);
if (config->file_loop) {
/* Let each source bin know it needs to loop. */
guint i;
for (i = 0; i < config->num_source_sub_bins; i++)
config->multi_source_config[i].loop = TRUE;
for (guint i = 0; i < config->num_sink_sub_bins; i++) {
NvDsSinkSubBinConfig sink_config = &config->sink_bin_sub_bin_config[i];
switch (sink_config->type) {
case NV_DS_SINK_FAKE:
case NV_DS_SINK_RENDER_EGL:
case NV_DS_SINK_RENDER_3D:
case NV_DS_SINK_RENDER_DRM:
/ Set the “qos” property of sink, if not explicitly specified in the
config. /
if (!sink_config->render_config.qos_value_specified) {
sink_config->render_config.qos = FALSE;
default:
break;
- Add muxer and < N > source components to the pipeline based
- on the settings in configuration file.
if (!create_multi_source_bin (config->num_source_sub_bins,
config->multi_source_config, &pipeline->multi_src_bin))
goto done;
gst_bin_add (GST_BIN (pipeline->pipeline), pipeline->multi_src_bin.bin);
if (config->streammux_config.is_parsed){
if(!set_streammux_properties (&config->streammux_config,
pipeline->multi_src_bin.streammux)){
NVGSTDS_WARN_MSG_V(“Failed to set streammux properties”);
if(appCtx->latency_info == NULL)
appCtx->latency_info = (NvDsFrameLatencyInfo *)
calloc(1, config->streammux_config.batch_size *
sizeof(NvDsFrameLatencyInfo));
/** a tee after the tiler which shall be connected to sink(s) */
pipeline->tiler_tee = gst_element_factory_make (NVDS_ELEM_TEE, “tiler_tee”);
if (!pipeline->tiler_tee) {
NVGSTDS_ERR_MSG_V (“Failed to create element ‘tiler_tee’”);
goto done;
gst_bin_add (GST_BIN (pipeline->pipeline), pipeline->tiler_tee);
/** Tiler + Demux in Parallel Use-Case */
if (config->tiled_display_config.enable == NV_DS_TILED_DISPLAY_ENABLE_WITH_PARALLEL_DEMUX)
pipeline->demuxer =
gst_element_factory_make (NVDS_ELEM_STREAM_DEMUX, “demuxer”);
if (!pipeline->demuxer) {
NVGSTDS_ERR_MSG_V (“Failed to create element ‘demuxer’”);
goto done;
gst_bin_add (GST_BIN (pipeline->pipeline), pipeline->demuxer);
/** NOTE:
* demux output is supported for only one source
* If multiple [sink] groups are configured with
* link_to_demux=1, only the first [sink]
* shall be constructed for all occurences of
* [sink] groups with link_to_demux=1
gchar pad_name[16];
GstPad *demux_src_pad;
i = 0;
if (!create_demux_pipeline (appCtx, i)) {
goto done;
for (i=0; i < config->num_sink_sub_bins; i++)
if (config->sink_bin_sub_bin_config[i].link_to_demux == TRUE)
g_snprintf (pad_name, 16, "src_%02d", config->sink_bin_sub_bin_config[i].source_id);
break;
if (i >= config->num_sink_sub_bins)
g_print ("\n\nError : sink for demux (use link-to-demux-only property) is not provided in the config file\n\n");
goto done;
i = 0;
pipeline->demux_instance_bins[i].bin);
demux_src_pad = gst_element_get_request_pad (pipeline->demuxer, pad_name);
NVGSTDS_LINK_ELEMENT_FULL (pipeline->demuxer, pad_name,
pipeline->demux_instance_bins[i].bin, "sink");
gst_object_unref (demux_src_pad);
NVGSTDS_ELEM_ADD_PROBE(latency_probe_id,
appCtx->pipeline.demux_instance_bins[i].demux_sink_bin.bin,
"sink",
demux_latency_measurement_buf_prob, GST_PAD_PROBE_TYPE_BUFFER,
appCtx);
latency_probe_id = latency_probe_id;
last_elem = pipeline->demuxer;
link_element_to_tee_src_pad (pipeline->tiler_tee, last_elem);
last_elem = pipeline->tiler_tee;
if (config->tiled_display_config.enable) {
/* Tiler will generate a single composited buffer for all sources. So need
* to create only one processing instance. */
if (!create_processing_instance (appCtx, 0)) {
goto done;
// create and add tiling component to pipeline.
if (config->tiled_display_config.columns *
config->tiled_display_config.rows < config->num_source_sub_bins) {
if (config->tiled_display_config.columns == 0) {
(guint) (sqrt (config->num_source_sub_bins) + 0.5);
config->tiled_display_config.rows =
(guint) ceil (1.0 * config->num_source_sub_bins /
config->tiled_display_config.columns);
NVGSTDS_WARN_MSG_V
("Num of Tiles less than number of sources, readjusting to "
"%u rows, %u columns", config->tiled_display_config.rows,
gst_bin_add (GST_BIN (pipeline->pipeline), pipeline->instance_bins[0].bin);
last_elem = pipeline->instance_bins[0].bin;
if (!create_tiled_display_bin (&config->tiled_display_config,
&pipeline->tiled_display_bin)) {
goto done;
gst_bin_add (GST_BIN (pipeline->pipeline), pipeline->tiled_display_bin.bin);
NVGSTDS_LINK_ELEMENT (pipeline->tiled_display_bin.bin, last_elem);
last_elem = pipeline->tiled_display_bin.bin;
link_element_to_tee_src_pad (pipeline->tiler_tee, pipeline->tiled_display_bin.bin);
NVGSTDS_ELEM_ADD_PROBE (latency_probe_id,
pipeline->instance_bins->sink_bin.sub_bins[0].sink, "sink",
appCtx);
else
* Create demuxer only if tiled display is disabled.
pipeline->demuxer =
goto done;
gchar pad_name[16];
/* Check if any sink has been configured to render/encode output for
* source index `i`. The processing instance for that source will be
* created only if atleast one sink has been configured as such.
if (!is_sink_available_for_source_id(config, i))
continue;
if (!create_processing_instance(appCtx, i))
goto done;
gst_bin_add(GST_BIN(pipeline->pipeline),
pipeline->instance_bins[i].bin);
g_snprintf(pad_name, 16, "src_%02d", i);
demux_src_pad = gst_element_get_request_pad(pipeline->demuxer, pad_name);
NVGSTDS_LINK_ELEMENT_FULL(pipeline->demuxer, pad_name,
pipeline->instance_bins[i].bin, "sink");
gst_object_unref(demux_src_pad);
for (int k = 0; k < MAX_SINK_BINS;k++) {
if(pipeline->instance_bins[i].sink_bin.sub_bins[k].sink){
pipeline->instance_bins[i].sink_bin.sub_bins[k].sink, "sink",
appCtx);
break;
if (config->tiled_display_config.enable == NV_DS_TILED_DISPLAY_DISABLE) {
fps_pad = gst_element_get_static_pad (pipeline->demuxer, “sink”);
else {
fps_pad = gst_element_get_static_pad (pipeline->tiled_display_bin.bin, “sink”);
pipeline->common_elements.appCtx = appCtx;
// Decide where in the pipeline the element should be added and add only if
// enabled
//------------------ I added here -------//
if (config->fenceplugin_config.enable)
// Create fenceplugin element bin and set properties
if (!create_fenceplugin_bin (&config->fenceplugin_config,
&pipeline->fenceplugin_bin)) {
goto done;
// Add fenceplugin bin to instance bin
gst_bin_add (GST_BIN (pipeline->pipeline), pipeline->fenceplugin_bin.bin);
// Link this bin to the last element in the bin
NVGSTDS_LINK_ELEMENT (pipeline->fenceplugin_bin.bin, last_elem);
// Set this bin as the last element
last_elem = pipeline->fenceplugin_bin.bin;
if (config->dsexample_config.enable) {
// Create dsexample element bin and set properties
if (!create_dsexample_bin (&config->dsexample_config,
&pipeline->dsexample_bin))
goto done;
// Add dsexample bin to instance bin
gst_bin_add (GST_BIN (pipeline->pipeline), pipeline->dsexample_bin.bin);
NVGSTDS_LINK_ELEMENT (pipeline->dsexample_bin.bin, last_elem);
last_elem = pipeline->dsexample_bin.bin;
// create and add common components to pipeline.
if (!create_common_elements (config, pipeline, &tmp_elem1, &tmp_elem2,
bbox_generated_post_analytics_cb)) {
goto done;
if(!add_and_link_broker_sink(appCtx)) {
goto done;
if (tmp_elem2) {
NVGSTDS_LINK_ELEMENT (tmp_elem2, last_elem);
last_elem = tmp_elem1;
NVGSTDS_LINK_ELEMENT (pipeline->multi_src_bin.bin, last_elem);
// enable performance measurement and add call back function to receive
// performance data.
if (config->enable_perf_measurement) {
appCtx->perf_struct.context = appCtx;
enable_perf_measurement (&appCtx->perf_struct, fps_pad,
pipeline->multi_src_bin.num_bins,
config->perf_measurement_interval_sec,
config->multi_source_config[0].dewarper_config.num_surfaces_per_frame,
perf_cb);
if (config->num_message_consumers) {
for (i = 0; i < config->num_message_consumers; i++) {
appCtx->c2d_ctx[i] = start_cloud_to_device_messaging (
&config->message_consumer_config[i], NULL,
&appCtx->pipeline.multi_src_bin);
if (appCtx->c2d_ctx[i] == NULL) {
NVGSTDS_ERR_MSG_V (“Failed to create message consumer”);
goto done;
GST_DEBUG_BIN_TO_DOT_FILE_WITH_TS (GST_BIN (appCtx->pipeline.pipeline),
GST_DEBUG_GRAPH_SHOW_ALL, “ds-app-null”);
g_mutex_init (&appCtx->app_lock);
g_cond_init (&appCtx->app_cond);
g_mutex_init (&appCtx->latency_lock);
ret = TRUE;
done:
if (fps_pad)
gst_object_unref (fps_pad);
if (!ret) {
NVGSTDS_ERR_MSG_V ("%s failed", func);
return ret;
Could help me that
(1)why the location is changed there is broken?
(2)Despite I have save the frame by the two plugin, but the lines can not be saved. please help me, and let me to how to move the dsexample plugin behind the “nvosd”.
Thank you very much
