Hello,I looked at the physics section of the omniverse docs and tried to drop the cube, but when I press play, I get the following error and the isaac smi doesn’t work.
Does anyone know the cause of the problem?
Any help or suggestions would be appreciated.
Thank you.
2020-10-15 09:15:25 [60,808ms] [Error] [omni.physx.plugin] PhysX error: Could not find registered CUDA function ‘updateBodyExternalVelocitiesLaunch’., FILE /buildAgent/work/ce945f8f79bc260f/source/cudamanager/src/CudaKernelWrangler.cpp, LINE 101
GPU MemCopyBalanced fail to launch kernel!!
2020-10-15 09:15:25 [60,841ms] [Error] [omni.physx.plugin] PhysX error: GPU translateAABBs fail to launch!!
, FILE /buildAgent/work/ce945f8f79bc260f/source/gpubroadphase/src/PxgCudaBroadPhaseSap.cpp, LINE 816
2020-10-15 09:15:25 [60,841ms] [Error] [omni.physx.plugin] PhysX error: GPU compute end point kernel fail to launch!!
, FILE /buildAgent/work/ce945f8f79bc260f/source/gpubroadphase/src/PxgCudaBroadPhaseSap.cpp, LINE 961
2020-10-15 09:15:25 [60,841ms] [Error] [omni.physx.plugin] PhysX error: GPU compute end point between block kernel fail to launch!!
, FILE /buildAgent/work/ce945f8f79bc260f/source/gpubroadphase/src/PxgCudaBroadPhaseSap.cpp, LINE 965
2020-10-15 09:15:25 [60,841ms] [Error] [omni.physx.plugin] PhysX error: GPU updateCreatedPairsKernel fail to launch!!
, FILE /buildAgent/work/ce945f8f79bc260f/source/gpubroadphase/src/PxgCudaBroadPhaseSap.cpp, LINE 929
2020-10-15 09:15:25 [60,841ms] [Error] [omni.physx.plugin] PhysX error: GPU radix sort fail to launch kernel!!
, FILE /buildAgent/work/ce945f8f79bc260f/source/gpubroadphase/src/PxgCudaBroadPhaseSap.cpp, LINE 661
, FILE /buildAgent/work/ce945f8f79bc260f/source/gpubroadphase/src/PxgCudaBroadPhaseSap.cpp, LINE 666
