I click on Localhost, a browser window opens up asking me to sign in. I sign in. Browser says you can continue work.
repeat this 3 times, I came here. I am now I have broswer windows that say I can continue, Create doesn’t get it.
hello @DataJuggler -
Can try and right click on “localhost” from the content window in Create and select “Remove Connection”.
Then click on “Add New Connection …” and enter “localhost” (remove quote marks for entry)
should ask you to login into Nucleus server again. Tell me results.
I was able to login doing something like that. I had to reboot to get it to work.
I will try your suggestion if it happens again.
