sudo gst-launch-1.0 uridecodebin uri=‘rtsp://10.42.0.68:8554/stream’ ! nvoverlaysink sync=0
Setting pipeline to PAUSED …
Pipeline is live and does not need PREROLL …
Progress: (open) Opening Stream
Progress: (connect) Connecting to rtsp://10.42.0.68:8554/stream
Progress: (open) Retrieving server options
Progress: (open) Retrieving media info
Progress: (request) SETUP stream 0
Progress: (open) Opened Stream
Setting pipeline to PLAYING …
New clock: GstSystemClock
Progress: (request) Sending PLAY request
Progress: (request) Sent PLAY request
Opening in BLOCKING MODE
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
reference in DPB was never decoded
NvxBaseWorkerFunction[2575] comp OMX.Nvidia.std.iv_renderer.overlay.yuv420 Error -2147479552
Please check if you can run this command:
$ gst-launch-1.0 videotestsrc ! nvvidconv ! nvoverlaysink
If you fail to run it and see identical error prints, we would suggest re-flash the system image.
moon@moon-desktop:~$ gst-launch-1.0 videotestsrc ! nvvidconv ! nvoverlaysink
Pipeline is PREROLLING …
Pipeline is PREROLLED …
moon@moon-desktop:~$ rm -rf ${HOME}/.cache/gstreamer-1.0
(gst-plugin-scanner:28272): GStreamer-WARNING **: 12:21:30.150: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so’: libtritonserver.so: cannot open shared object file: No such file or directory
(gst-plugin-scanner:28272): GStreamer-WARNING **: 12:21:30.224: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so’: librivermax.so.0: cannot open shared object file: No such file or directory
ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error.
Additional debug info:
gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0:
streaming stopped, reason error (-5)
Execution ended after 0:00:00.000287400
Setting pipeline to READY …
Setting pipeline to NULL …
Freeing pipeline …
What does this mean
The command is simple and should work fine on either release. Are you able to do clean re-flash and try again?
Yea it worked
