I Got Jetson Nano Dev Kit (SUB) . Without SD Slot. How to install linux?
Hello?
I got jetson nano . First buy. first use.
When I watch youtube. there are use SD-Memory Card. for install OS
But my kit… include 16G eMMC but no have SD-CARD. slot
Yahboom Jetson Nano 4GB SUB Developer Kit with 16G-eMMC Based on Official Jetson Nano 4GB Core Module (Jetson Nano 4GB SUB) : Electronics (amazon.com)
I was buy this one…
I just know jstson nano and 4GB
How Can I install with SD memory?
Thank you read. not good english.
Follow the steps at Install Jetson Software with SDK Manager.
NVIDIA SDK Manager can be installed on Ubuntu 18.04 host PC to flash Jetson with JetPack 4.6.1
It’s mean use cable? right?
with SD memory slot use sd memory card. for intall
without SD memory slot use cable? for install.
right?
Correct.
FYI, there are two models of Nano (well, more, but 2 that matter in this case): With SD card and without eMMC memory, versus no SD card, but eMMC memory. Both use the USB cable and JetPack/SDK Manager to flash.
Thank you~ ^.^
May I ask another one?
Today I installed VMWere for intall Ubuntu.
and I download Ubuntu last version is 22.04
If I use jetson nano … only use Ubuntu 18.04? or Can use 22.04?
Thank you
VM is not supported, and may have USBconnecting problem.
Still, we only suggest to use a native Ubuntu 18.04 host PC.
Thank you~ I will try it~
