hello, i have a problem with 310.44 driver on my notebook, with GT640M/I7/8G/HD4000
i installed 310.44 32-bit driver from here
http://cn.download.nvidia.com/XFree86/Linux-x86/310.44/NVIDIA-Linux-x86-310.44.run
on centos 6.4 (32-bit…
here are my steps:
use command:
[root]# yum install -y kernel-devel gcc make binutils
to prepare minimal soft requirements(these softs are the minimal requirements from the README.txt from 310.44 driver…
after install basic soft, download the 310.44 driver(linux 32-bit. and save it in /tmp/ -
blacklist the nouveau driver, modify /etc/modprobe.d/blacklist.conf ,add “blacklist nouveau”
rebuild initramfs image, by command:
[root]# mv /boot/initramfs-#(uname -r…img /boot/initramfs-#(uname -r…img.bak
[root]# dracut -v /boot/initramfs-#(uname -r…img #(uname -r. -
modify /etc/inittab, change the contents “id:5:initdefault” into “id:3:initdefault” to start centos in character mode.
after start centos in character mode, use command:
[root]# lsmod | grep mouveau
to confirm that nouveau is not running. -
use command :
[root]# chmod +x nvidia*.run
[root]# ./nvidia*.run
and i install it without any problems ,and then show me the success sign.
i use the default .conf file created by the installing program. and the installing program save my old .conf file as well. -
reboot centos, and i still get into the character mode. i use command :
[root]# lsmod | grep nouveau
without any output, which means the nouveau driver is not working, and it’s correct.
then, i use command:
[root]# lsmod | grep nvidia
with output that shows there are nvidia driver running -
[root]# init 5
and then centos can’t open the graphic mode…the screen is black for a long time without any responds. -
i had to force to restart centos, and use “linux single” to log in centos, then ,i found:
Fatal: no screens found
in Xorg.0.log file!!!
besides, the xorg.conf file generated by installing program contains 10 screens in .xonf file…
i try to rewrite the BusID:1:0:0 in the last second part.
the BusID comed from
use command :
[root]# lspci | grep NVIDIA
… 's output
however it’s not help.
how can i install nvidia offical driver on centos 6.3/6.4 (32-bit.?
thanks for your patient to answer my questions…
