hi,
if i use 608 608 on pgie and sgie, deepstream works well, but 1536 1536 on pgie and sgie, deepstream will be hung after 20-30 minutes, said scale problems on sgie!
pls give an advice to get it work normally,
thank you very much!
hi,
• DeepStream Version
• TensorRT Version
hi,
my platform is jetson nx and deepstream5.1.
thank you
What does this mean? What have you set as “608” or “1536”?
hi,
it is for custom yolo model, trained by 608X608, or 1536X1536, or 412X412, like that.
thanks!
It may be caused by SGIE. When the model dimension is 1536x1536 and the PGIE detects objects whose size is less than 256x256, the HW scaler can not scaling the object to the model size for the HW limitation(Jetson HW can only scale 1/16 to 16 ratio). Please avoid such configuration.
ok get it.
