I have an AGX XAVIER and I want to install JetPack 5.1.2 for learning
Link Please!
I have an AGX XAVIER 32gb and I want to learn everything before upgrading.
Thanks ever so much !
Kermit Frazier
Hi kkfrazier1,
  1. JetPack 5.1.2 archive page — download links, release notes, and component list
    JetPack SDK 5.1.2 | NVIDIA Developer
  2. NVIDIA SDK Manager — the recommended installer for JetPack 5.1.2 on an Ubuntu 20.04 host
    SDK Manager | NVIDIA Developer
  3. L4T 35.4.1 Developer Guide — the reference manual for the BSP that ships with JetPack 5.1.2 (flashing, boot flow, kernel, secure boot, everything)
    Welcome — Jetson Linux Developer Guide documentation
  4. Jetson AGX Xavier Developer Kit User Guide — hardware layout, recovery-mode button sequence, and carrier board reference
    Jetson Download Center | NVIDIA Developer
Recommendation: Install SDK Manager on an Ubuntu 20.04 host (22.04 is not officially supported for JetPack 5.1.2), plug your AGX Xavier into the host via the USB-C port on the module side, put the board into recovery mode, and let SDK Manager do the flash plus CUDA/cuDNN/TensorRT install. The Developer Guide chapter “Quick Start” walks through exactly that flow.
Hope this helps!
I want to Thank You Profusely, and I feel like an Idiot for asking (again) but I cannot find a link or button anywhere.
I have downloaded the file: jetsoninstaller-r38.4.0-2025-12-30-17-00-37-arm64.iso
I this is the one, I’ll quit squawking & get busy!
Thanks Again, Kermit Frazier
Thank You! I think its finally sunk in that what I need to start with is the SDK then go from there.
Thanks again!
Hi Kermit,
Quick heads-up on the file you downloaded: jetsoninstaller-r38.4.0-*.iso is a real NVIDIA release, but it’s the JetPack 7 / L4T r38.4 installer, which supports only Jetson AGX Thor, T5000, and T4000. It will not flash an AGX Xavier.
For your AGX Xavier, stay on the JetPack 5.1.2 path:
  1. Install SDK Manager on an Ubuntu 20.04 host
  2. In SDK Manager, pick JetPack 5.1.2 (L4T 35.4.1) as the target — not the latest
  3. Flash from there
You can discard the r38.4.0 ISO.
Hope this helps. Thanks.
