Hello I have a EdgeCore switch with Brocade cumulus which is no longer supported. I believe this is the same hardware as the SN3700’s. Can this switch be re-flashed with Nvidia Cumulus ?
Here is an extract from the Switch Info which shows a Nvidia serial number.
10.32.1.204
cumulus@sl-100Gswitch-a03:mgmt:~$ decode-syseeprom
TlvInfo Header:
Id String: TlvInfo
Version: 1
Total Length: 629
TLV Name Code Len Value
Product Name 0x21 64 MSN3700C
Part Number 0x22 20 SSG7A80803
Serial Number 0x23 24 M1LM28P001U
Base MAC Address 0x24 6 90:0A:84:9F:88:00
Manufacture Date 0x25 19 08/24/2022 22:24:15
Device Version 0x26 1 1
MAC Addresses 0x2A 2 254
Manufacturer 0x2B 8 Mellanox
Vendor Extension 0xFD 52 0x00 0x00 0x81 0x19 0x00 0x2E 0x00 0x02 0x07 0x98 0x00 0x00 0x31 0x00 0x20 0x00 0x00 0x00 0x00 0x00 0x07 0x07 0x07 0x07 0x07 0x07 0x07 0x07 0x07 0x07 0x07 0x07 0x07 0x07 0x07 0x07 0x07 0x07 0x07 0x07 0x07 0x07 0x07 0x07 0x07 0x07 0x07 0x07 0x07 0x07 0x07 0x07
Platform Name 0x28 64 x86_64-mlnx_msn3700C-r0
ONIE Version 0x29 23 2019.11-5.2.0020-115200
CRC-32 0xFE 4 0x919C5AA5
(checksum valid)
root@sl-100Gswitch-a03:mgmt:~# cat /etc/os-release
NAME=“Cumulus Linux”
VERSION_ID=4.2.0
VERSION=“Cumulus Linux 4.2.0”
PRETTY_NAME=“Cumulus Linux”
ID=cumulus-linux
ID_LIKE=debian
CPE_NAME=cpe:/o:cumulusnetworks:cumulus_linux:4.2.0
HOME_URL=“http://www.cumulusnetworks.com/”
SUPPORT_URL=“http://support.cumulusnetworks.com/”
root@sl-100Gswitch-a03:mgmt:~# mlxfwmanager
Querying Mellanox devices firmware …
Device #1:
Device Type: Spectrum2
Part Number: MSN3700-CxxxC_Ax
Description: Spectrum™-2 based 100GbE 1U Open Switch with Cumulus Linux; 32 QSFP28 ports; 2 Power Supplies (AC); Standard depth; x86 CPU; RoHS6
PSID: MT_0000000202
PCI Device Name: /dev/mst/mt53100_pci_cr0
Base MAC: 900a849f8800
Versions: Current Available
FW 29.2007.1292 N/A
Status: No matching image found
10.32.1.205
cumulus@sl-100Gswitch-a04:mgmt:~$ decode-syseeprom
TlvInfo Header:
Id String: TlvInfo
Version: 1
Total Length: 629
Serial Number 0x23 24 M2NJ27D000F
Base MAC Address 0x24 6 90:0A:84:97:22:00
Manufacture Date 0x25 19 07/22/2022 18:09:27
CRC-32 0xFE 4 0xC890B325
(checksum valid)
cumulus@sl-100Gswitch-a04:mgmt:~$ cat /etc/os-release
VERSION_ID=4.2.0
ID=cumulus-linux
ID_LIKE=debian
root@sl-100Gswitch-a04:mgmt:~# mlxfwmanager
Thanks for your help.
