deepstream-app: error while loading shared libraries: libnvinfer.so.5: cannot open shared object file: No such file or directory
Have you install TensorRT from sdkmanager first?
You can check it with the following command:
$ dpkg -l | grep nvinfer
If no package is found, please install the packages with sdkmanager again.
Yes, this is the first time I installed tensorRT.
I install tensorRT with Tar File Installation
but i checked. no package was found
Would you mind to reinstall the component packages from the sdkmanager again?
