Hi all,
the latest Video Codec SDK video decode application note mentions the following as one of the latest improvements:
Memory optimization for I/IDR-frame only decoding: Enables user to achieve memory optimization if the use-case involves decoding of I/IDR frames only. This support is currently available for H.264, support for other codecs will be added in future drivers. It can be enabled through a flag exposed the NVDECODE API.
Ok, but what is the “flag” to use? Looking through the documentation I did not find out how to activate this feature.
Thanks for your help.
Alex
