I installed deepstream 6.3 environment, when I run the program, why does it load the dependencies of deepstream 6.1?
GPU
• DeepStream Version
6.3
• TensorRT Version
8.4
535.54.03
The original environment of my machine was deepsteam6.1.1, and then I uninstalled it by running sudo ./uninstall.sh according to the official tutorial, and deleted cuda and tensorRT, etc., and then reinstalled the deepstream6.3 environment according to the documentation, but why did I run the program it will still load deepstream6.1? Why is my tensorRT version 8.4? Logically speaking, it is 8.5
root@box:/home# deepstream-app --version-all
deepstream-app version 6.3.0
DeepStreamSDK 6.3.0
CUDA Driver Version: 12.2
CUDA Runtime Version: 12.1
TensorRT Version: 8.4
cuDNN Version: 8.4
libNVWarp360 Version: 2.0.1d3
root@box:/home# python3 support_multi_rtsp.py
File “support_multi_rtsp.py”, line 5, in
import pyds
ImportError: /opt/nvidia/deepstream/deepstream-6.1/lib/libnvds_meta.so: cannot open shared object file: No such file or directory
My original environment is deepstream6.1.1,the steps to uninstall the environment are as follows:
1.Uninstall deepstream(https://docs.nvidia.com/metropolis/deepstream/6.1.1/dev-guide/text/DS_Quickstart.html#dgpu-setup-for-ubuntu)
2.Uninstall cuda:
sudo apt-get --purge remove "*cuda*" "*cublas*" "*cufft*" "*cufile*" "*curand*" \
 "*cusolver*" "*cusparse*" "*gds-tools*" "*npp*" "*nvjpeg*" "nsight*" "*nvvm*"
3.Uninstall driver:
./NVIDIA-Linux-x86_64-xxx.run --uninstall
or
a.sudo apt-get --purge remove "*nvidia*" "libxnvctrl*"
b.sudo apt-get autoremove
c.find / -name "*nvidia*",Manually delete the driver that does not match the query result using rm -rf
4.Uninstall tensorRT:
sudo apt-get --purge remove libnvinfer8=8.4.1-1+cuda11.6 libnvinfer-plugin8=8.4.1-1+cuda11.6 libnvparsers8=8.4.1-1+cuda11.6 \
  libnvonnxparsers8=8.4.1-1+cuda11.6 libnvinfer-bin=8.4.1-1+cuda11.6 libnvinfer-dev=8.4.1-1+cuda11.6 \
  libnvinfer-plugin-dev=8.4.1-1+cuda11.6 libnvparsers-dev=8.4.1-1+cuda11.6 libnvonnxparsers-dev=8.4.1-1+cuda11.6 \
  libnvinfer-samples=8.4.1-1+cuda11.6 libcudnn8=8.4.1.50-1+cuda11.6 libcudnn8-dev=8.4.1.50-1+cuda11.6 \
  python3-libnvinfer=8.4.1-1+cuda11.6 python3-libnvinfer-dev=8.4.1-1+cuda11.6
  1. If you run native deepstream-app, can it work normally ?
  2. try which deepstream-app to find path of deepstream-app then run ldd deepstream. what the output ?
3.try install.sh in /opt/nvidia/deepstream/deepstream
  1. user_deepstream_python_apps_install.sh reinstall python bindings.
  2. It is recommended to use docker, which is a simple and convenient method
Hi, I met you again, my old friend. You are really amazing. Thank you for your suggestion. I have redone Python binding to solve the problem. By the way, do you know why my TensorRT version is not 8.5?
ls -l /usr/lib/x86_64-linux-gnu/libnvinfer.so
Does this library exist? Is its soft link to version 8.4?
Maybe you can try docker
Yes, it exists. Docker is excellent, but this is a development environment
/usr/lib/x86_64-linux-gnu/libnvinfer.so → libnvinfer.so.8.5.3
If you execuse install.sh in /opt/nvidia/deepstream/deepstream to flush cache
Or reboot ?
Are there any changes?
I’m not quite sure why this is the case
I’m sorry, it still doesn’t work.Anyway, thank you for your help
