I keep having problems connecting to my DGX Spark founders edition with NVIDIA Sync using my MacBook Pro 16 inches 2019 with the latest version of Sequoia.
Initially I had problems connecting with my Spark but I was able to connect at least tree times (I raised a ticket into this forum but I connected later so I didn’t follow), however sessions only lasted while my MacBook Pro session until shutdown. I installed Cursor, AI Workbench, Open WebUI and ComfUI during those connections.
However after the lap shutdown, when restarting my lap with the already created NVIDIA Sync session, it appears me the following error :
I did a lot of things, like deleting the known_host file in the path /Users/darusi/.ssh (8 times) , also the config file like this:
Also I deleted the configuration into the NVIDIA Sync directory as follows:
I reinstalled NVIDIA Sync lots of times (10 or more) but no connection happened.
Reviewing the log file, it appears like there is no route to host, however we are on the same network with no device between like a FW or router as follows:
“level”:“error”,“pid”:4228,“error”:“dial tcp 192.168.68.111:22: connect: no route to host”,“addresses”:[“192.168.68.111”],“time”:“2025-12-28T22:06:08-06:00”,“message”:“Could not dial any address for 192.168.68.111:22”}
{“level”:“error”,“pid”:4228,“error”:“dial tcp 192.168.68.111:22: connect: no route to host”,“time”:“2025-12-28T22:06:08-06:00”,“message”:“Could not dial 192.168.68.111:22”}
{“level”:“warn”,“pid”:4228,“error”:“dial tcp 192.168.68.111:22: connect: no route to host”,“time”:“2025-12-28T22:06:08-06:00”,“message”:“could not get remote environment variables”}
I can access the DGX spark through ssh with no issues, I’ve been able to start certain dockers processes like Open WebIUI and Cursor, but not Nvidia AI Workbench, that presents the very same error:
So is consistent with the NVIDIA Sync error. I’m attaching the logs with the evidence for your analysis since I want to restore my NVIDIA Sync connection:
nvsync.log (18.7 KB)
NVIDIA Sync-desktop.log (730.3 KB)
Any comment or support please let me know
Thanks in advance
