I’m having issues with NVIDIA ffmpeg package as it is having a conflict with libavcodec.so.58.134.100
sudo apt install ffmpeg
[sudo] password for jdraper:
Reading package lists… Done
Building dependency tree… Done
Reading state information… Done
The following packages were automatically installed and are no longer required:
libavcodec58 libavformat58 libavutil56 libssh-gcrypt-4 libswscale5 libvdpau1
Use ‘sudo apt autoremove’ to remove them.
The following NEW packages will be installed:
ffmpeg
0 upgraded, 1 newly installed, 0 to remove and 14 not upgraded.
Need to get 0 B/17.3 MB of archives.
After this operation, 56.2 MB of additional disk space will be used.
(Reading database … 208908 files and directories currently installed.)
Preparing to unpack …/ffmpeg_7%3a4.4.2-nvidia_arm64.deb …
Unpacking ffmpeg (7:4.4.2-nvidia) …
Replacing files in old package libavutil-dev:arm64 (7:4.4.2-0ubuntu0.22.04.1+esm6) …
Replacing files in old package libpostproc-dev:arm64 (7:4.4.2-0ubuntu0.22.04.1+esm6) …
Replacing files in old package libswresample-dev:arm64 (7:4.4.2-0ubuntu0.22.04.1+esm6) …
Replacing files in old package libswscale-dev:arm64 (7:4.4.2-0ubuntu0.22.04.1+es
m6) …
dpkg: error processing archive /var/cache/apt/archives/ffmpeg_7%3a4.4.2-nvidia_a
rm64.deb (–unpack):
trying to overwrite ‘/usr/lib/aarch64-linux-gnu/libavcodec.so.58.134.100’, whic
h is also in package libavcodec58:arm64 7:4.4.2-0ubuntu0.22.04.1+esm6
dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
Errors were encountered while processing:
/var/cache/apt/archives/ffmpeg_7%3a4.4.2-nvidia_arm64.deb
E: Sub-process /usr/bin/dpkg returned an error code (1)
Hi Please refer following page about ffmpeg
