I meet errors when install components, did anybody meet the same problem?
13:49:04 INFO : CUDA Toolkit for L4T : Depends: cuda-documentation-10-0 (>= 10.0.326) but it is not going to be installed
13:49:04 INFO : CUDA Toolkit for L4T : E: Unable to correct problems, you have held broken packages.
13:49:04 INFO : CUDA Toolkit for L4T : Unhandled error when running sudo apt-get -y install cuda-toolkit-10-0
13:49:04 INFO : CUDA Toolkit for L4T : exit status 1
13:49:04 INFO : CUDA Toolkit for L4T : [ Package Install Finished with Error ]
13:49:04 INFO : CUDA Toolkit for L4T : [ 20.00 KB used. Disk Avail: 43.62 GB ]
13:49:04 INFO : CUDA Toolkit for L4T : [ NV_L4T_CUDA_TARGET_POST_INSTALL_COMP Install took 1m43s ]
13:49:04 ERROR : CUDA Toolkit for L4T : command scp -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no /tmp/tmp_NV_L4T_CUDA_TARGET_POST_INSTALL_COMP.sh tx2@192.168.56.2:~; ssh -t -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no tx2@192.168.56.2 "~/tmp_NV_L4T_CUDA_TARGET_POST_INSTALL_COMP.sh && rm -f ~/tmp_NV_L4T_CUDA_TARGET_POST_INSTALL_COMP.sh" finished with error
13:49:04 ERROR : CUDA Toolkit for L4T : command terminated with error
Hi jiangjixiang,
It should be download package fail.
Please try delete cuda-repo-l4t*.deb file on your download folder and download again. Thanks!
